i think thats why ur friend is telling u it could blow it up .. if u set it very high .. it might creep higher than the turbo can tolerate .. but 10 psi should be fine .. r33 should be able to stand 13 or maybe 14 absolute max .. run 12 absolute max to be safe is the general consensus ... someone correct me if i'm wrong.
I use a GFB bleeder (I think it's called the Atomic Boost Controller or something along those lines). My mechanic is a GFB reseller so he gets their parts quite cheaply. I've forgotten the price, but it was around $60 or slightly more. I was going to make my own, but at that price the parts would have been more. I really like GFB products as they're cheap and do the job.
My TurboXS one works fine on my R32 GTST.
I've set it to 13psi and on a cold night, when I mash my foot, it will spike to about 14psi then settle back down to 13psi..
I bought it 2nd hand for $50.
new they are about $110.. (retail)
the GFB atomic is also $110 (retail). unless you know someone..
yeh you got it cheap..
details for those that haven't seen the GFB boost controller.
Quote from GFB..
"GFB puts the key to boost control in YOUR hands! All turbocharged vehicles utilize some form of factory boost control, most of which display a tendency to be conservative in allowing the boost to build up, and then taper away noticeably toward redline (see diagram). A GFB Boost Controller however, not only allows quick and easy boost level adjustment, but it can also reduce the boost threshold (the RPM at which boost starts to rise) and maintain a rock-steady upper limit.
The simple explanation is - more power, earlier and longer!
$109 including GST (Part No. 3001)"
My RB20det runs 12psi at the manifold and I don't have a bleeder but does have stock dump/front pipe,2 1/2inch zorst,pod and no cooler:rolleyes: .Don't flame me for no cooler as a supra front mount is going in soon:uh-huh:
Guest Boxhead
umm the GFB atomic whatever bleed valve is what i have in myn set for 12, i was told by dyno tuner is that if you keep the lines shorter, you will get less spike, and on teh dyno, we set it for 12psi, and it spiked to 12.3 at max i think.....
so my advice is keep lines short....
secondly, i think autobarn sell it for like $69 or 70 but its not that dear...
Originally posted by rev210
bleeder systems don't stack up very well against electronic boost control. The boost is quicker to build and more stable on the ebc.
I would love to turf the turbosmart bleeder valve.
no-one is argueing against that..
I just couldn't justify that much cash
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
