All very interesting. But last time i checked we were on a wonderfully green and blue earth, not hell. You havent addressed the simple fact that R33 owners are all of dubious sexual orientation. R33s are known to be susceptible to germs and disease and often end up pink with 20" chromies, yellow leather and more fibreglass then a catamaran. The roof line is good on foggy mornings as with such a high seating position bird strikes become a real concern, but hey, the fog is all the way down there.
Then there is this whole RB25 thing. Nissan threw cheaper and weaker pistons and rods at the car...and thought to themselves, hell we have thrown all this weight at the unsuspecting Nissan enthusiast, we better given them displacement so they dont notice the extra lard. So throwing a weaker engine in the heavier car fitted well with the deisgn intent Nissan had for the R33 GTS25t, they knew most were going to be painted pink and get chrome wheels. So knowing what the owners had in store didnt bother with making a decent car.
I know the above to be true. If you doubt it then you can line up your
against my lowly R32 GTSt. The loser has to run down the drag strip at Calder on Friday night naked with their old fella chock a block up a chicken.
why would u want to have 'shitty' r33 parts on ur pretty 32? >_<
why would u want to have 'shitty' r33 parts on ur pretty 32? :)
Because i can only push this feeling inside me down so many times. It is eating me up inside. My car needs more R33 parts! :(
I found a good buy on good shocks and it woudl be almost worth modifying the car to accomodate, but maybe not. :yes:
Because i can only push this feeling inside me down so many times. It is eating me up inside. My car needs more R33 parts! :iluvff:
I found a good buy on good shocks and it woudl be almost worth modifying the car to accomodate, but maybe not. :D
As you know the top shock mounts on R32 rears are at the inner guard in the boot, on R33's they are up under the rear parcel shelf. Hence R33 springs and shocks are much longer than R32's. Knowing you, you will want a precise number, R33 shock body 440 mm versus R32 shock body 330 mm.
I suppose you could use them and raise your car 110 mm..................
:) cheers :)
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
