r33 i assume? if so then that is a stock dump pipe. if youe want to complete the exhaust you need a dump and front pipe as well. if your cat is also stock upgrade that to a highflow.
there are a few traders on sau selling these components. search aroung in the classifieds and you'll find something to suit.
also id recommend doing a bit of reading b4 you purchase. there are plenty of debates on here about each of those products and you'll learn something bout your car as you do
Yeah as Basti said. You need:
Dump pipe/front pipe (comes as 1 piece). Or alternatively you can purchase a separate dump pipe and separate front pipe.
High flow cat converter (if you don't have one already). If the cat you have has an inlet & outlet smaller than 3inchs it'll be a standard cat.
As for the dump/front pipe they come in 2 styles, Bell mouth dump & Split dump. Split is said to be better. I can't say as to which is better as I have a bell mouth dump and have not tried the split. However the bell mouth I fitted made a huge difference.
Talk to Just Jap and I'm sure they can work something out for you for a very reasonable price.
yup, stock
I got a bellmouth type from JustJap for $220 delivered around a year ago. stainless steel good value
JustJap sell the split system for $249 atm.... looks to be a top deal.
the sort of dump pipe that will best suit you depends on how much modifying you plan on doing. if you are going to keep it relatively stock then anything is going to be better than nothing. i got just over 200kw with a cheap ebay dump pipe, but i did modify it slightly to flow better.
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
