Just to confirm we have the next "Hot Imports Night" on Thursday 14th June.
AND WILL BE CONTINUING TO DO SO ON EVERY SECOND THURSDAY OF THE MONTH!!!!!!!!!!
We will organise some prizes for the competitors
we are also starting our Circuit Tag race competition. Qualifying rounds every Thursday.$1000 cash plus prizes to be won by the winner of the final held at 9.30pm on June 28th
. PLEASE TRY MAKE THIS BIG GUYS
SHOW CARS ARE INVITED DOWN AND CARS WILL BE PUT INSIDE FOR VEIWING PRIZE FOR BEST CAR ON THE NIGHT VOTED BY ME
The Drag Tag info web site http://site.dragtag.com.au/
.>>>>>>>>>>>> Can you please put up the information for next week on the various web sites THANKS<<<<<<<<< PLEASE PEOPLE
NO STUPID COMMENTS PLEASE
COPS KNOW ABOUT DRAG TAG AND ARE FINE WITH THE VENUE NO COPS WILL BE WAITING TO DEFECT YOU
BUT WITH THAT SAID IF YOU DRIFT DOWN THE ROAD WHEN YOU LEAVE DONT EXPECT ANYTHING LESS THAN THE FULL EXTEND OF THE LAW
THANKS GUYS AND GIRLS
https://www.sau.com.au/forums/topic/172567-drag-tag-this-thurs-night/
Guest
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
