i have a RB24 with hks gt2540 and im looking into cams for it. so rb20 cam info is what im looking for.
from what i understand ive heard a lot of ppl using the tomei poncams in/ex 256 with 8.5 lift. these are stage 1 i believe.
what are the differences if i was to go stage 2? guessing the valve springs would need to be changed also.
guessing that cam gears dont have to stay same brand as shafts also???
what are the gains to be made and price/availability on everything.
BIG thanks
matt
https://www.sau.com.au/forums/topic/172591-cams-and-cam-gears/
yo huddy time for bigger lump lump cams
and bigger turbo I think 3037 or td06 25g lol
step 2 cams normally would require some sort of valve spring upgrade on a rb20 saw some upgrade springs the other day cheap
otherwise highoctane do them for $540-$740
cams are always on yahoo brand new mainly tomei ones $200ish each so probably around $600+ landed
then you gotta get gears I would just get the same brand although other brands should fit
all up look at close to 1k for a set of step 1's installed closer to 2k for step 2 due the vavle springs
this also all depends on the lift you get aswell there may well be step 2's out there that dont require the springs to be done?
Huddy im about to install cams on my RB20 set up and have looked into it a fair bit the last few weeks.
You would be waisting your money with 256 cams and also cam gears in my opinion. You want to be matching the cams with your set up and also what your goals are with the engine eg: are you wanting to make more top end or quicker response???
With the 24 and your turbo then i would be looking at either 264 or 270 cams. When it comes to upgrading your springs (can be costly) again it depends on the lift of the cams you go with and how much boost you are going to be running and the health of the stockers.
I've been told that the stock springs will be ok upto 9.1lift but anything over that then you would have to replace.
Price wise has been a little varied with the quotes i've got so far, and then when i think i have found a bargain i seem to get stooged :)
Interested to see your results :banana:
GMB
grandmasterb...if one were looking for quicker response instead of more top end then would 256s be ok?
and huddy...didn't you have a 2530 on your car and not a 2540?
Really depends on your current set up and what your goals are cobber???
hmm ok
might just go gears for now - as simple to fit, even if there is no gains, at least i can utillize them later down the track.
i did used to have the GT2530, but i've got the GT2540 now - 241rwkw ;) feels nice.
Let us know how it goes :)
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
