Eoi:rb26 Motor & Rb25 Gearbox.
Aside from the fact it is likely fuel related if it is black, the symptoms otherwise sound like worn valve stem seals. Oil gets past the worn seals when the engine is off and burns when the engine starts. If it happens on deceleration while driving (puffs of white smoke) that is another valve stem seal symptom because oil gets sucked form the head into the combustion chamber under vacuum with the throttle closed. They can be replaced in the car if you have some way to keep the valves closed while working (eg compressed air into cylinders) but is much easier with head off.
Alright, fair enough. Expected as much. Possibly, yes. However the kit is apparently not including every single hose and it is out of stock too.
I sourced my silicone hose kits from Just Japanese. Their current link is what I posted above but supplier might have changed over the decades.
No, you cannot perma-bend hose once it is already made.
So bending them yourself isn't feasible?
