Wont go into gear under Med to High Revs
R31Heaven
 Share
Went to Heathcote drags on the Weekend and my car won't change up into third if the revs are above 4 grand it just grinds any idea of the problem, except my box has a problem, wich is abvious:( would changing to a good oil fix this or is it a more serious problem as a synchro gone.
could also be either your clutch is dragging or your spigot bearing seized, not allowing the input shaft to spin freely of the engine. Is it only going into third or other gears as well?
 Share
