I bought these 3 weeks ago to assist eliminating tuning and defect issues. But the problems have been fixed without fitting these parts. And now I need funds to help pay the bill.
And the manifold was new when i bought it. It is a greddy replica. I'm trying to make this obvious because the guy tried to sell it to me as a genuine item. Anyway.. I have spent about 10 hours polishing the runners in the manifold because I wasn't happy with the casting finish. I never tried to port it bigger, I just took enough off to make the surfaces smooth.
Throttle body sold
Manifold dropped SOLD
Edited by lrc135
https://www.sau.com.au/forums/topic/172673-sold/
The thottle body is uses but in excelent condition. And does not reqire an adaptor for the manifold below.
And the manifold was new when i bought it. It is a greddy replica. I'm trying to make this obvious because the guy tried to sell it to me as a genuine item. Anyway.. I have spent about 10 hours polishing the runners in the manifold because I wasn't happy with the casting finish. I never tried to port it bigger, I just took enough off to make the surfaces smooth as.
Asking $600 ono for both
Sorry if this is a silly question but is this is for RB25DET?
https://www.sau.com.au/forums/topic/172673-sold/#findComment-3177537
I bought these together so I didn't think of seperate prices. But since the manifold is $350, I will sell the throttle body for $250
Now dropping price to $550 for both.
Pics tomorrow maybe. I will try to borrow a camera.
https://www.sau.com.au/forums/topic/172673-sold/#findComment-3183530
  • 3 weeks later...
;) polished inside :P
Polished internal runners cause fuel to form droplets which can result in idling issues. It is best to leave the inside of runners rough to prevent this from happening.
How can that be when the fuel is injected at the end of the runners right at the inlet face of the head. Fuel would not even touch the runners. All I have done is stop some turbulance buy removing shitty casting finishes. Had the casting been neat like the rest of the manifold I would not have cared.
Maybe it happenes with other manifolds but not this one.
https://www.sau.com.au/forums/topic/172673-sold/#findComment-3215817
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
