have you taped up the coils at all? if not try that too. i'd clean the terminals in the coils then tape them up. i think that should help.
or you could have someone sit under the bonnet while you go for a drive..........
are you offering? lol
here's the thing though. at 10psi theres no prob.
at 11 psi theres no prob.
so far it's only happened at 12+
i set my boost to 10psi, and i never intended to run 12psi.
so by my reasoning, if i keep boost under 11, it shouldnt be a problem, right?
Edited by Munkyb0y
what is happening is that the spark is basically being blown out. there is too much fuel/air for the spark to ignite. platinum plugs are only good becuase they are supposed to last a long time but i don't think they spark as well as coppers or iridiums.
i second mad082 with my life.
i would never use plats ever. theyre only good for engines where the sparkplugs are hard to get to.
most of us on here have had that problem, spec with r33's.
if you have access to a test meter, get it checked out.. from memory i think if the resistance is around 200k its ok.. if its around 8k then its faulty.. the coil packs..
id start with the simpler things tho, clean coils, spring, tape/silicone the coils.. chck for any arcing..
at night, take it for a hard drive till it happens.. lift the bonnet and give it a rev or 2.. check for any arcs.. if u see arcs then uv found the culprit!
so you guys think iridiums will be a better plug, if it turns out my coils are fine?
(i'd rather not use coppers. i've heard too many stories of them breaking down after less than 5000 kms).
also, can u explain the coil pack resistance test in a bit more detail.
cheers
Edited by Munkyb0y
i ran coppers on my 33 at 14psi and they lasted 10,000kms before i changed them, and they weren't missing at all. they still had probably another 5,000 or 10,000kms in them. they are less than $4 each, so it isn't that expensive. the iridiums i took out of my car were supposedly only about 20,000km old and they were shagged. iridiums are about $25 each and don't really last that much longer. if you use coppers, the money you will spend on spark plugs over a 50,000km period would be the same as buying 1 set of iridiums.
either bcpr6es, or bkr6es (i'm not 100% sure if the bkr ones had an s on the end or not). they are basically the same plug, the bkr one is just a v groove plug. but i have run them both with good results.
  • 3 weeks later...
hey guess what? the mechanic i used for my major service just after i bought my car, who overtensioned my timing belt, and i went back, got him to redo it, then told him he's a monkey, and will never go back again. well that same c0cksucker ordered and installed ngk platinums 1.1mm, after i specifically told him to use the 0.8mm.
anyway, i had my coil packs out last week to check for cracks, burns, etc.... and i pulled out my plugs while i was at it, and found the wrong gap. regapped them to 0.8mm. so far so good. no more missfire. hopefully this solved it for good. i didnt bother touching the coil packs.
Edited by Munkyb0y
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
