i think that old (the larger throttle body does nothing for you is bull) my opinion .
Yeah i agree with ya. Did you see the Autosalon article from ages ago where all they did was a Hypertune throttle upgrade? They left the same sized pipework, just used a silicone reducer and gained 10-15kw through out the rev range and that was on a stock turbo at it's limits. That's decent gains in my books.
  • Replies 533
In some ways it's like upsizing the turbine. Less restriction to the whole air in / air out process should equal easier power.
Can you post up a decent picture of the throttle cable mount?
ok ill do that for you
Thanks for those - the detail is great. I'm in the same boat as zebra.
Do the angles work ok?
yep you have to bend the bracket a bit also have the bracket a bit sideways make it first then shape it on a belt sander to make it look like its a straight fit,i hope you know what i mean.its has to be at a angle so the cable wont hit the plenum and is straight in front of the throttle body ,also the holes to the bracket make slits so you can move it in the position you need. (belt sander last thing you do)
Edited by WARLORD
Yep, the end result sort of tells the story - I did notice that slight kink.
Searching through my ally and steel supplies I may use either some 50 x 50 x 6 angle ally, or 50 x 6 flat steel as a starting point. Either way should work fairly well, but probably yours as a template is the easiest.
Main point is to get that cable pulling from the right spot, in a fairly straight plane and avoid that bloody kink that I've seen a few people end up with as the cable runs into the plenum.
thanks
With some help from my mate, we knocked up this item. As shown, 90% complete - it needed a slit cut for the cable to slip through, and a coat of paint.
One area we paid attention to was getting a dead straight pull on the throttle linkage. Hopefully our placement of the hole gives a nice sweep for the cable leading up to the bracket.
Bugger all materials used in making the thing, but I don't think it would be easy to get the positions right with manifold and throttle body all bolted up to the engine. Very similar in execution to yours Warlord, and definitely handy to have some fabricating skills.
one small but big thing is the cable must sit behind and fit under the plenum look at mine again as the firt one i made would not let the cable fit in with out jamming it in which i do not recomend ill measure the lenght you need it looks close ill let you know tomorrow
Edited by WARLORD
Did you measure the boost at WOT before the throttle body and found it was higher than the boost after the throttle body, hence proving that the throtte body was a restriction?
I have, at 315 rwkw and guess what? The boost was the same, hence proving that a larger throtte body would have achieved nothing, except waste time and money.
Cheers
Gary
Surely just a boost difference before and after the throttle isn't an indication of whether a throttle body will give gains throughout the rev range :P
It may not be a restriction at those power levels, however it doesn't mean that no more performance can be gained.
If you upgrade the size of the throttle and pipework to suit it can allow more airflow at the same boost pressure does it not?
Airflow (Q) = Velocity (V) x Cross sectional Area (A)
An increase in the cross sectional area at the same velocity means an increase in airflow (CFM). So why would it not make more power, regardless whether it's a "restriction" or not?
I'm an Engineering student so if i am wrong please explain why as i am curious about this whole throttle upgrade.
Here's the Autosalon article i was talking about earlier.
Edited by PM-R33
Cheers
Gary
i really think you need to re test.
its not a waste if it is done properly like every mod should be done not just chucking it on and hoping for the best you should know that.
the dyno has increase boost and the car was not even re tuned.
if you are going to turn this into somthing please don't post here as this is my topic with the results i have achieved and i don't want it to turn stupid again.
love always. lol
Nick
Edited by WARLORD
yer that will not work
I got it to work this morning :rofl2: (i have the standard throttle body with adapter though)
its not 100% perfect but pretty damn close.
I had to make a spacer for the accelerator pedal and cable but that was easy enough
Surely just a boost difference before and after the throttle isn't an indication of whether a throttle body will give gains throughout the rev range :rofl2:
That doesnt make sense to me - if it doesnt restrict airflow it is not going to affect power.
You've assumed velocity is constant, which is not true.
Each section of the intake path introduces pressure loss (except the compressor of course!) and in some cases the loss introduced by a particular section is negligible, which is what Gary is saying. Checking the boost either side will tell you if there has been pressure loss. Lower pressure = less air mass = less power. If the piping into and out of the throttle are the same ID as the throttle, there's unlikely to be a change of much gain. If you're changing plenum to a larger ID, its likely to help.
Are you studying fluid dynamics at the moment? IIRC that's where this stuff is covered.
Now back on topic: Warlord you're a nut, but in a good way. The car is very nice.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
