  • 4 weeks later...
  • Replies 533
They're good, except I recommend changing those nuts and bolts Installed mine today and stripped the thread on one of the bolts with not a lot of effort using a 1/4 ratchet....
Had to use a nut splitter to get it off.
Bought some high tensile bolts n nuts on the way and that was fine
  • 1 month later...
so its finished and tuned.
426kw@713ftlb on 24psi unfortunately i had some major intake leaks that we found after the tune after doing a smoke test and ethanol level was at 72% ,the leaks are now fixed and will be going back to check the tune again with a higher ethanol level.
the car is scary as hell after not driving it since feb. at almost 600hp its a bit of a hand full but with some suspension tweaks i hope it will feel a bit better
the dyno graph was not best run on the day but it gives you an idea.
Edited by WARLORD
  • Like 4
fuuarkkk x 10000
Congrats man!
Rear end wise, get some traction rods and extend them by about 15mm each side, then toe in the rear 1mm each side. Will help heaps with keeping the traction down (this reduces the camber ramp & toe out on squat).
  • Like 2
    • Are we at the point where Barra/LS swaps are the cost effective replacement for 30yo RBs which no-one can find?
    • I'd need to check my notes at work Duncan, but I'm pretty sure most of that is purely OBD2 on the display. How quickly is it all able to update? Do you have any internet capability in your workshop with a laptop?
    • Yeah just gonna be near stock runner only want 180kw to 210kw can’t find anything been looking ages looked in to rb25 but money is tight as the moment need the car back on the road
    • From there it is trickier. Ecutek seems to be one of those closed ecosystems where everyone password protects their tunes which means I either choose a tuner and can't change from them and can't make any changes myself for any reason, or I have to buy the tuning software (about $4k) and then get someone to tune from scratch (which is not simple with all the multi dimensional tables these days). Once you buy about 300 "flash points" per ECU you can get it tuned and add their "RaceROM" function which hacks extra functionality like launch control onto the ECU, and also makes extra data available for logging over CAN Not sure what I'll do there yet; I'm tempted to use one of the overseas shops that does billions of remote tunes of the platform instead of starting from scratch locally, a lot can be done online these days.
