finally got it tuned after fixing some problems it made 321.7kw and 820nm ill post a dyno sheet up after i fix the last to little problems and its put back on the dyno
a vid if anyone wants a look
  • Replies 533
Good stuff Nick.
What size gauges are those? My car no longer has aircon so im thinking of putting my gauges in the vents.
Dave they are 60mm and a bit of a cu%t to fit but it can be done.
  • 7 months later...
Hey mate just read through this thread.
I've got to stay it is one of the best build threads I've ever read. It's given me lots of inspiration or my own build and lots to think about. Keen to read more about your build in the future.
Also out of interest are/were you sponsored by HDI? Apologies if you said so but I'm pretty tired and read all this in one sitting! :D
And the net of that is a much better looking car without the HDI advertising.
Nicks car surprised me...when it was making 320kw the power delivery was very responsive and hard!
Perfect combination IMO...I can't even imagine what this new setup will be like! What can this new setup make Nick, over 400kw?
    • Only reason I started replacing hoses was I went for a short drive to the shop the other day and finished shopping and started the car and started to drive off and could see a big trail of fuel in the rear view mirror. Parked up and found the bottom hose to the fuel filter had busted. Lucky I was near a car part store and was able to get a replacement hose and back on the road. But got me thinking I had owned that car for around 20 years and was all original fuel hoses so probably time to replace all of the fuel hoses. Was pretty lucky it went where it did.
    • A few kg falling from a few feet is enough to move parts of your skull inwards into your brain Also, there's always news about people getting crushed, and occasionally killed, working under cars Be safe is your endeavours
    • I was just going to replace the fuel line and keep the stock one, but they do look pretty nice lol.
    • Are you going to delete the stock damper or are you just replacing the fuel lines and keeping the stock damper?  There are also options for sexy ones if the stock one is too ugly for you lol -  https://www.radiumauto.com/Fuel-Pulse-Damper-Inline-Kits-P751.aspx or https://www.radiumauto.com/Fuel-Pulse-Damper-Direct-Mount-Kits-P759.aspx So sexy.
    • I think you guys are right. The only reason I thought it was a restrictor was I had seen the same yellow band on the r32 boost restrictor. Will just replace with a standard fuel hose. Thank you for your speedy replies. I'm sure I'll have many other silly questions.
