not just the snorkel but the filter to,most of the good pods flow 600cmf and panel filters flow 430cmf so in my world adding two pod filters that are good for a 140-180cmf each will help some what,only the end dyno will tell if it works or i have a a nice bit of modern art in my car.lol
Edited by WARLORD
  • Replies 539
I like it, should work well, but are you sure the panel filter is restricting flow? Mine is sitting at 350kw on a Blitz element atm.
It would be simple to test restriction without cutting the holes, just pop out your filter on the dyno and see what the gains are. I keep meaning to do it with my car but I always forget/run out of time.
i found that when i added a pod to the air box it was more responsive than with out so if i have time on a dyno ill try both as i have 2 air boxes one modded and one stock as a rock but i felt the difference on my set up.i should feel a bigger difference with the bigger turbo.
Holy smokes man! Just stumbled upon this thread... What a cracker of a job you have done! I have just got myself a gtrs and had it tuned and love it to bits haha.
There was a bit of hate at the start there and some more in the middle but you have continued to update and post here, and for that I reckon your a f**kin top bloke haha what a champ! I would have thrown my hands up in the air and said stuff ya all after the first bit of hate posting.
Again, good work mate :)
  • 5 weeks later...
thanks Badcredit33 its been fun over the years looking at kids post there shit
UPDATE
well its together and running but need a tune.
Edited by WARLORD
its a gtx but not a 3071r its bigger low mount still +pump gas should see 380kw ish on pump as my chat today with the tuner he is surprised so far and can't believe the torque this combination makes he thinks ill see 400kw atw and around 950nm ill be happy with what ever it ends up with.
the aim is for 22-23 psi @8200rpm limit
for those how could not be F reading it all it made
322kw@840nm 8200rpm with 24 psi on a hks 3037 pro s (wich is now making 307kw on a rb with its new owner that dvs tuned)
Edited by WARLORD
    • Make sure to have the block checked for cracking etc before doing anything.
    • Pull it out. Put a suction hose on it drawing from a bucket of petrol. Put a discharge hose on it pointing back into the bucket. Add 12V. That will tell you if it works at all. Then put it back in, turn the engine on, and see if there is 12V on the terminals. That would suggest that it runs when the car does and adds its "capacity" to the total pumping system.
    • So you're telling me this is an external fuel pump? I've had the car for at least 6 years now and it's been there the entire time. I had the car tuned a couple years ago and I had the shop do the fuel system, including a new in-tank Proflow 340 which shit itself about a year later and I replaced it with the same model. I find it odd that they didn't remove this or even make mention of it. I seriously had no idea what it was. How would I test if it's functioning?
    • Don't take it as a guarantee. It's all a game of statistics. And on top of that, smooth over a thick layer of "quality of spanner spinning" as a further Gaussian curve of probability of failure. You play games at anything above ~400 HP, and you're using up margins in terms of engineering and luck.
    • Aye, everything is being touched and all the parts that are responsible for the oiling issues are also fixed. (Crank collar, billet prp oil pump, head return to sump, yada yada yada)  Everything used is of reputable brands like greddy, prp etc. My tuner did mention we’d keep the torque on the “lower” side.   glad to read that my engine won’t blow up on me lmao
