so nick...i heard u got it retuned, or is this just a rumour?
o did you now lol yep it did
soooooooooooooooo after being totally disgusted with my past tune in more ways than one i took the car to a professional JEM (Adam) an not a self proclaimed prodigy as i did be for.
after taking 20 deg of timing out of the tune and fixing all the holes and flat spots and much much more errors the car is perfect.
things jem did for me
Tune the car in the way it was supposed to be done from the beginning.
engine protection set up with oil press,inlet temp and wide band sensor
wire meth to map sensor
wire press sensor
install wide band
replace temp sensor
new plugs
road tune after dyno with me driving
and a total respect from beginning to end of the customer and all done in 2 days not 16 days
all this for a $400 more than my worst experience ever who did F/A
turbo spools much earlier boost is much smoother it makes 200 odd nm of torque more a/f ratio is 11.8 be for it was 12.8
end result it a well tuned 356kwatw with 913 nm or 672.7 ftlb @ 8200 rpm
take me for a spin take me for a spin lol :action-smiley-069::action-smiley-069::action-smiley-069::action-smiley-069:
me me me me
sounds good to me will find some time with marko and who ever won't one day
Edited by WARLORD
  • Replies 539
Wow, sucks to hear the old tune was THAT bad... Flags raised for me from things you mentioned though, so really glad you took it to JEM who yet again convince me that they are a class act, and glad it happened before damage wad done! Congratulations on a good result :-)
thanks, i was told that im lucky the engine is still alive,or even running with the settings i compared i am totally shocked,
i should really be given back my money for all the bullshit i went through
Edited by WARLORD
So did Adam do a back to back run with the old tune? Would have been good to see an overlay of both
IMO if JEM is capable of tuning the ATCC GIO GTR, they know what they are doing...this is when JEM gained my respect
Great to see u are finally happy after a very long and rough run nick
  • 2 years later...
you twisted my arm things that have been changed or being changed.
valve springs,rear arms ,fuel setup: rail ,injectors, fuel pump,e85 solenoid,diff gears to 3.9, gtx3582r ,sinco manifold ,wastgate ,seats,and more shit i can't remember
should be ready soon i hope a fair bit of fabricating to do but that's ok .....i hope.
last year s/m 1000
https://www.youtube.com/watch?v=bvEaDXwRy8g
Edited by WARLORD
  • Like 3
That Sinco manifold is a true work of art and it's not only me that thinks this....I've never seen such good fabrication!
Hey Nick, what is the puff of smoke towards the end of that run from rear cabin view? Is that when u hit the Flux Capacitor injection :)
    • Nothing wears "the most". Different cars will always show signs in a different place. 114000 km is either nothing at all (as in, given the calendar age, nearly brand new) or it's completely unbelievable. We stopped believing numbers like that about 15 years ago. Having said that, my car is up around 270000 km and I have put bushes into some places** as many as 10 times in >25 years that I've owned it. ** FUCAs, which are different on an R32 than on a 33, so not likely to be the same issue for you. I have original ball joints all the way around. They are perfectly fine. Same with the spindle bearings in the front. Tie rod ends have all been done at least once though. Pretty much every other bush in the car has been done at least twice. Some of those in the first 100000km after I got it (which was at a genuine 23000!). Some of those bushes are now sphericals, and they are on a <cough> regular maintenance schedule, hence why my FUCAs have been rebuilt so many times. Half of those 10 in the count above would be in the last few years! 'twere I you, I would budget on replacing everything, for fun and prevention. If they really are 30 year old rubber, they will all be unpleasantly aged in one way or another. Whether that's corrosion of shells, or the rubber cracking, or sagging under the load, etc etc.
    • Tighten until it starts to get loose again, then back off 1/4 turn?
    • Do them as you'll find when you remove them they are perished/dried.    Its probably one of the best things to do as makes the car so much more responsive. Do ball joints while there too.
    • Hi All Got an R33, about 114,000km on the clock.  Handles very nice, no signs of issues.    Engine is out and i'm doing an underbody refresh, mainly painting subframe, cosmetics etc. Can't see anything physically giving play, but I'm wondering which bushes are the ones that wear the most, or the first ones that may give problems down the track? For good measure I'm thinking to fit new ones. Thanks
