  • 3 months later...
  • Replies 533
Just read your post from start to finish.
Good to see the progress from start to finish.
Did you go bigger in the injectors from the 800 odd cc ones.
I have a similar setup with the gtx3582r and 1000cc injectors with a 3l built bottom end ported neo head s2 pon cams.
Currently on run in tune. 5000 rpm limit  14psi i see 349rwhp so 260rwkw with no timing as had a problem with the tps. On pump 98. When its run in i will be throwing bigger injectors at it  ew ecu instead of the nistune.
Hopefully see around 480 to 520 on pump and 600ish on e85. Still debating on the e85.
All built by myself. Including my own exhaust manifold and 3.5 inch dump pipe and 3 exhaust that i made.
Bare in mind i have it in a lc gtr torana that tips the scales at 1057kgs.
  • Like 2
Injectors are rotchester 1000cc that flow 1090cc .the e85 road is a good one but its best to keep up your maintenence and not the best to leave your car sitting around for long periods . Also found once you start climbing higher coil packs and harnesses need to be good order .
But with the weight of your car you will shit your self the first couple of times you hit it ...lol if you get a chance to run a 1000 meter event you have some fun in that car.
My next step once i find my other problem out is to run nos again so that 500kw that marko is talking about be achievable i hope . Good luck with the let us know how you go.
That is a very nice conversion but I am biased as well as I have a soft spot for toranas :)
  • 1 year later...
31 minutes ago, WARLORD said:
Thanks
car still providing boners? haven't heard about it in a while!
Also these days, the Bosch 1550cc aka 1650cc (as most retailers call them) are 100% unmodifed where as the 1250cc are still milled to get that flow rating.
yer car is still around just haven't had time to play with it ... I am thinking of reconnecting the nos again with a 75 shot  for something to do but i know the clutch will die. need to find a new clutch,
That will be clutch number 6 since 2006 . ive tried so many types now and only found the jim berry to have lasted my abuse i should of keep it.
may use the nitrous to only get the turbo  on, as a form of anti-lag - would make it like a V8
You still on a single plate? maybe have a chat with Scott at Western Clutch in St Mary and pop in a twin plate.
got a os str twin and i think i have over heated the pressure plate  after killing a lambo and a mclaren
are they good rebuilding clutches
Edited by WARLORD
They have the right tools to do what you dream of, they have a clutch pressure plate testing tool as well!
I've got a Exedy clutch modified by them to clamp 1.7 tons with a carbotic disc and the pedal effort is like a stock manual Corolla.
27 minutes ago, WARLORD said:
how much for this new addition
Somewhere around the $1k mark installed (this was a while ago) - yours might be different in price as it's a twin plate
  • 8 months later...
  • 2 years later...
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
    • Well, the NC is just an RX8 anyway, right?
    • Now Mark, I know you've already done an engine swap, but how about doing an engine swap that reduces a lot of weight, and effectively makes it a mid mount engine setup?   https://youtu.be/A99702U07QI?feature=shared
