Base settings are based on jap fuel. May cause engine to ping. Best keep it until you are about to go tune. Plug in, drive to get it tuned, then drive away happily. Just don't get to happy on the throttle with base settings.
https://www.sau.com.au/forums/topic/17272-power-fc/#findComment-356294
Hi INASNT, run it on Optimax or Ultimate. Check the detonation levels on the Commander, it is not normally a problem. Used to be before the 98 octane fuels came out, not so much now.
If it is showing excessive detonation, let me know and I will run through the Commander menus with you and take some ignition advance out of it, easy.
Hope that helps
https://www.sau.com.au/forums/topic/17272-power-fc/#findComment-356459
Guest INASNT
silver arrow
i could do that but the car will run like a big agaian with the rich a/f settings of the stock ecu!
sydneykid
i always run on 98 anyway and driving to work and back in peak traffic the car doesent see more than 50% throttle anyway!
the stock maps cant be that bad for 98 ron can they?
https://www.sau.com.au/forums/topic/17272-power-fc/#findComment-356467
