The plates from Lorenz's stolen '31 Passage were spotted on a GTR this morning... Has anyone had a blue 32 GTR stolen?
ive seen couple of blue32 gtrs around. i take it they were just normal plates, nothing custom
i dont park mine in public anymore, got a crappy oldsmobile for that. couldnt pay a car theif enough to steal it. when i 1st got my gtr after huming about it i left it parked at the shop during the day for like 1 hr and someone tried to take it, done 1400 damage. lucky someone busted them in the act and scared em off. but spewing as it all come out of my pocket with the excess being way higher.
i keep seeing GTR's parked in way worse spots than i did, wont say where because they might park there regularly. but i dont know how they get away with it.
atleast mines safe at home, got a pretty good alarm system, and it takes me like 10min of reversing and driving forward just to get it out of the bs spot i have to park it in. that and there's 2 cars infornt of it with alarms and a dog likely to tear some nuts off. i highly recomend these safety measures for all GTR's
that and make sure no one follows you home, hit 270km just to be sure :D well maybe you dont need to go that far.
Edited by gzilla
Ive worked it out, what you need to do is get some magnetic GT-R badges.
When you park, you pull ur GT-R badges off and there you have it, its not a GT-R anymore. Just stick 'em back on when you get back in.
But on a serious note that is some scary stuff. Computers that hack into the alarm and imobiliser is a daunting thought, these theives get more and more professional.
Makes you want to go out and get some of this gear:
http://www.carsecurity1.co.uk/autoTaser.htm
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
