For Sale:
Im selling the standard turbo off of my 1996 R33 Series II Skyline. Its a T25 Turbo with a T3 exhaust flange, the series II turbo differs from the series I turbo by having a different compressor wheel which allows a bit of a quicker spool up. Turbo is a good upgrade for an RB20 or whatever else you want to chuck it on.
Condition:
The turbo is in excellent condition with no shaft play. Max boost i ran on the turbo was 10psi for about a year, before that the car was stock as a rock so ran on stock boost.
The turbo was taken off of the car a few weeks ago with about 80,000km on the car, reason for sale is that im upgrading to a bigger turbo.
Price and price conditions:
Im chasing $300 for the turbo and would prefer local pickup however shipping could be organised at buyers expense.
Contact Details:
You can contact me on 0421 735 333 or PM me on this site.
Townsville
Thanks, Phil
post-35676-1181802579_thumb.jpg post-35676-1181802655_thumb.jpg post-35676-1181802726_thumb.jpg
Edited by PM-R33
https://www.sau.com.au/forums/topic/172767-r33-series-2-turbo/
PM's replied to.
I need this turbo gone, may include shipping in the $300 in QLD if any one is seriously interested.
Perfect condition turbo, you will not find a better conditioned standard turbo than this one!
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
