  • Replies 51
screamer and straight 4" out the side infront of p.s back wheel. You cant think at idle and its clearly one of the loudest cars at the track. Its so loud when you go past the commentary tower at qr, you can hear the cars exhaust as feedback through the speakers when they talk. The flames are another story ;)
X force stainless 3" split dump pipe bolted onto a JIC magic 3" engine pipe
bolted onto an x-force stainless cat bolted onto a
HKS silent hi-power 3" exhaust.
The system is actually quiter than my stock exhaust at certain rpms, but absolutely growls when I open up the throttle. No drone at all which is a big bonus to me.
custom 3 inch dump pipe with screamer to magnaflow 650cfm cat, to 3.25 inch 5zigen Border exhaust. not bad for an exhaust made in 1998, its quiet as per normal then when opened up sounds very nice.
Edited by Pauly33GTS-t
has anyone bothered to do the calculations on what a 2inch, 3inch, 4 inch system will actually flow?
you'll find that even a mandrel bent 2.5 inch system has enough capacity to flow like 400hp.
I don't remember the calculations exactly.. I think Sydney Kid had posted them at one point.
3 inch system
single dump pipe
exhaust is:
turbo to cat (unknown brand) mild steel
magnaflow high flow cat
then magnaflow stainless steel all the way back
dual tip at the end, looks steathly apart from the fact it's shiny :blink:
larger resonator (high tech mufflers) dropped noise from 92db down to 85db, didn't really notice any power decrease
i dont think anyone really cares how much they flow outright, its a matter of what works better :domokun:
a 2.5" pipe may flow enough for you to make 400hp, but if switch to 3" your sure to make a decent gain.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
