A Problem Of The Skyline?
What are they. Some sort of knock-off Sumitomo copy? Or originals "reconditioned"? Do they come with pins and springs and anti-rattle/squeal plates, or are you going to have to spend almost as much again getting those too? I also have no idea if the hoses on the 34NA will suit those, and if they don't, what hoses you would need to buy, or perhaps get made, to make it work.
Read my post above. It tells you what to do.
Hello everyone, haven't signed in for years! But here i am again 😂… anyways, i am planning to order these calipers on ebay with the z32 rotors and pads… that would be everything i need to upgrade my ER34 Gt non turbo Coupe?? thank you! What about the mounting bolts? Same? Is there a difference between z32 calipers like turbo and non turbo? … so i can get the correct rotors and pads
The link doesn't seem to work for me. Any chance you can reupload it?
I figured out what’s wrong. It’s something to do with the high beam wire short circuiting. When I measure the continuity with a multimeter on the headlight socket connector it gives me a continuous beeping noise when I put it on the ground socket and also on the high beam socket. On the passenger side of the car (working side), it’s only beeping when the probe is on the ground socket. Which makes sense. So that means it has something to do with the high beam power supply for the drivers side. How do I trace that? Is it the turn signal lever malfunctioning? The one that also controls the high beam and low beams.
