Hi All,
My mates car has just been stolen from where he works "The Goodguys" near Greenhill Road and was last seen driving down Greenhill Road about 20 minutes ago.
It's a 4 door pillarless HR31 Passage,
Number plates "LORENZ"
cant miss it, cops are on the case but if anyone see's it please pursue it or report to cops straight away. or alternatively ring him on 0419 035 068
Cheers,
Ev.
https://www.sau.com.au/forums/topic/172827-stolen-hr31-pillarless/
yeah thats my car
any help would be appreciated guys
im f*kn spewn hard atm
was stolen from my work when i was working literally an hr ago (around 9pm), was seen on greenhill road by ex gf minutes after it was taken
guy had bacl hair and black scruffy beard, was driving along with a silver r33 aswell
yes it was the home maker centre, behind bunnings
please pass the word around and keep an eye out, i no its only a car but it means soo much to me as im sure alot of u would understand!
thanks for any help
Lorenz
Someone's eyed it up for sure. Any security? If not, then he must know the w*nker some how.
Never tell anyone what alarm system you have in your car guyz... OR park in Blacktown NSW. This might happen to your beloved line. I feel the pain everyday. GET UR LINE SECURED!!!
Sorry evosR31 im no help but i hope he finds it dude...
i have some good news Grin
car was found this morning, just got a call then from the police!
was found in watlle park, shes in 1 piece at least, wheels still on the car, few scratches down the drivers side. theyve f**ked the ignition set up so not very driveable atm, but they dumped it due to running out of petrol! had about an 1/8th of a tank in there so knew they couldnt have got far! headunit was stole, dno about the speakers as they are hidden behind the door trims and they couldnt get into the boot to nick my subs unless they had a key or pulled the seats out or f*ked the boot lock up so ill wait and see about that!
thanks to everyone who has been out, passing on the word and generally trying to find the car, i appreciate it sooo much Smiley
should pik the car up 2day, so more updates later!
yeah thats my car
thanks for any help
Lorenz
OI Lorenz I was being cat-mouse around by two R31's (One for sure I saw a P plate) last night at 12 and I have a Silver R33 S2, but as I said it was at 12. Good to hear the cops found the car
Edited by Pauly33GTS-t
Good to hear that you got your car back, all i can say is that i hate (with a Passion) car theifs the little %&$*Wits should have their hands and feet cut off. Hope its not to thrashed like my old VK was :) u feel so dirty when u get back in ur car ;)
Seems like a skyline is stolen every couple of weeks, and dumped a couple days later. Wonder if its the same f**kers after a quick ride cause they cant afford their own.
When my car was recovered, clothes and maccas wrappers were in there, couple of tools, and a phone voucher purchased from Oaklands park while my car was missing. Dont know if the cops ever followed it up to get video footage of the person who bought it, or find out what mobile number it recharged.
You must be relieved to get it back, i've seen so many stolen cars dumped in the Adelaide hills + torched.
sheeeet, thats a thick trail leading to the guys, doubt the cops will follow i tup.
me and a mate were walking down the street one night and came accross some drug dealers standing out the front of their lab, apparently they thought we were cops so got bashed + chased with a machete and shotgun through streets. long story but the cops never did anything!!!
said its our word against theres and to go home its past our bed time.
The druggies thought you were COPS and bashed you and chased you with a Shotgun?! WTF! Who would do that to someone they thought was a cop?!!!! Musta been on those homemade drugs themselves!
Sorry to hijack thread, this is the first pillarless R31 i've seen. Is that a mod you've done yourself, or was there a model released with that? Looks good!
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
