Yay I have found access to Nissan Fast. I have been using it for personal use to locate part numbers the R32 GTR manual does have.
The reason I use it personally was because I was getting tired of ringing up Nissan to get someone with a crappy attitude and wasting 30mins trying to explain what I am after, with respect they are very helpful.
So if you want to save time on the phone trying to describe the part your after to the Nissan Dealers send me a PM on what you need and I'll do my best to find your OEM part number you can take to Nissan. **I take no responsibility on the integrity of the part number that is given**
I know there is something like this in the forums but i couldnt find it.
---MODS--- if I am crossing some boundaries here, just delete this topic.
As a minimum i need:
Model (ie. R32)
AND/OR
VIN-code or Chassis Code (I havent used this yet, it is beneficial for coloured parts, ie panels)
Name of item wanted
General description
-Have Fun
https://www.sau.com.au/forums/topic/172841-w00t/
Great guys, thanks for your replys.
If you guys jump on my signature theres a link to the topic in the DIY.
I have only started a little bit but it will get big, one day, with everyone's help.
This time I hope it stays and becomes a very valuable tool for SAU members.
Yes the FAST is a awesome tool, im bored of it already haha.
Mark - Yes I have details of s13's which I can post up as well on my little topic.
https://www.sau.com.au/forums/topic/172841-w00t/#findComment-3182209
hI GUYS,
Just installed it and after putting my VIN and Model No in, im getting this
VIN NO. NOT FOUND.
Car is a 1992 r32 gtst, and i have these CDS a1, a2, a3, b1, b2, gl, gr.
If that makes any sence.
I hope my car isnt using a fake VIN....
Also im running v3.50 what version are you guys running? This seems very old, like it was suitable for windows 98 and lower.
Edited by Antone
https://www.sau.com.au/forums/topic/172841-w00t/#findComment-3182242
hI GUYS,
VIN NO. NOT FOUND.
assuming you have installed yours correctly, all u need is the details on blue plate of your car. Chassis No and Model Number
eg. for r33 gtr
Chassis No. BCNR33 then next box 023211
Model GGJPRWFR33ZDAAA--A
https://www.sau.com.au/forums/topic/172841-w00t/#findComment-3182416
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
