Yay I have found access to Nissan Fast. I have been using it for personal use to locate part numbers the R32 GTR manual does have.
The reason I use it personally was because I was getting tired of ringing up Nissan to get someone with a crappy attitude and wasting 30mins trying to explain what I am after, with respect they are very helpful.
So if you want to save time on the phone trying to describe the part your after to the Nissan Dealers send me a PM on what you need and I'll do my best to find your OEM part number you can take to Nissan. **I take no responsibility on the integrity of the part number that is given**
I know there is something like this in the forums but i couldnt find it.
---MODS--- if I am crossing some boundaries here, just delete this topic.
As a minimum i need:
Model (ie. R32)
AND/OR
VIN-code or Chassis Code (I havent used this yet, it is beneficial for coloured parts, ie panels)
Name of item wanted
General description
-Have Fun
https://www.sau.com.au/forums/topic/172841-w00t/
Great guys, thanks for your replys.
If you guys jump on my signature theres a link to the topic in the DIY.
I have only started a little bit but it will get big, one day, with everyone's help.
This time I hope it stays and becomes a very valuable tool for SAU members.
Yes the FAST is a awesome tool, im bored of it already haha.
Mark - Yes I have details of s13's which I can post up as well on my little topic.
https://www.sau.com.au/forums/topic/172841-w00t/#findComment-3182209
hI GUYS,
Just installed it and after putting my VIN and Model No in, im getting this
VIN NO. NOT FOUND.
Car is a 1992 r32 gtst, and i have these CDS a1, a2, a3, b1, b2, gl, gr.
If that makes any sence.
I hope my car isnt using a fake VIN....
Also im running v3.50 what version are you guys running? This seems very old, like it was suitable for windows 98 and lower.
Edited by Antone
https://www.sau.com.au/forums/topic/172841-w00t/#findComment-3182242
hI GUYS,
VIN NO. NOT FOUND.
assuming you have installed yours correctly, all u need is the details on blue plate of your car. Chassis No and Model Number
eg. for r33 gtr
Chassis No. BCNR33 then next box 023211
Model GGJPRWFR33ZDAAA--A
https://www.sau.com.au/forums/topic/172841-w00t/#findComment-3182416
    • Definitely the stroker kit. once you mention you have a RB28 everyone will assume you will flog them and hopefully won't start asking about support mods. Anyone will be too scared to race you, except maybe the RB30 boys
    • Just a quick update: I decided to go ahead with the de-cat for now. The exhaust shop inspected the catalytic converter and said it was in good condition. I took a look myself, and it does not appear broken nor clogged. After the de-cat, the car feels more responsive and smoother. The shop also reinstalled the exhaust temperature sensor into the de-cat pipe, and now the warning light no longer comes on, even when driving hard. The only thing that’s bugging me is the tinny, “can-like” sound the exhaust makes now (similar to having a hole in the muffler). The shop suggested that I might need to replace the muffler. I'll have to think on what to do next.
    • I want to start upgrading but don't have the budget to drop 15k at once, if i was to do one first which would be better and why?
    • Yuh. It is very rare for a single turbo to throw ceramic into the engine. Quite common on GTRs. As I posted above. Mine did destroy the O2 sensor on the way out though! Plastic compressor is fine with the temperature. It's not some flimsy PE/PET/PP thermoplastic. It's a thermoset resin with reinforcing material in it (a composite, as posted by @Lithium above). The compressor never sees much more than 100°C because it's never boosting very high. If you boost it high enough to make a lot of temperature, then the turbine will depart the scene and stop the party anyway.
    • From what I understand, it's a ceramic turbine and a plastic compressor (not sure how it doesn't melt then lol) I heard the series 2 r34 gtt has a metal turbine but I doubt that. @GTSBoy When you blew your standard neo turbo it didn't cause damage from memory just the turbine ended up in the cat?
