Car:
1993 model Series 1 R33 GTST type M - RB25DET
Rego to 29/10/08
94000kms
Plate number - GTS25M
Fast info:
Prod: 93/10
Colour: KH2 (Gunmetal Grey)
Interior Colour: K
Engine: RB25DET
Drivetrain: HICAS 2WD
Model: GTS25T/M
Trans: 5-MT
Details:
1st Aussie owner - imported in April 04 - owned it for 3 years.
Serviced every 5000kms using full synthetic oils.
Timing belt replaced at 60000kms.
Clutch and brake fiuids replaced with redline fluids regularly.
Mods:
Apexi Power fc and commander.
Apexi AVCR.
Apexi turbo timer.
Hybrid GT spec front mount.
Generic oil cooler.
Apexi power intake with custom CAI box.
Custom stainless 3" split front and dump and CATCO high flow cat.
X-force stainless 3" cat back exhaust and muffler. Nice low note.
Generic oil catch can.
Splitfire coil packs.
Tomei high flow fuel pump.
Omori oil temp gauge.
Trust sensor adaptor.
apexi mechanical boost gauge.
Trust dual pillar holder.
Nismo 320kmh gauge cluster.
C's short shifter.
Cusco quick release hand brake.
Trust shift knob.
Momo Jet steering wheel.
HKB boss kit.
Cusco front and rear strut braces.
Cusco brake cylinder stopper.
Nismo oil and radiator cap/covers.
Whiteline springs.
Whiteline sway bars (front and rear).
Whiteline adjustable castor and cambor kit(front and rear).
Bilstein adjustable shocks.
DBA slotted disc rotors (front and rear).
Race brakes pads (front and rear).
Carbon layered vented bonnet with pins.
Genuine East Bear front grill.
Genuine East Bear dry carbon boot lid.
Genuine M sports front bar.
BN sports style skirts and rear bar.
Gunmetal/chrome 18" Buddy club P1's (265 rear + 255 front).
R33 GTS4 chrome headlights.
Nismo smoked side indicators.
Kenwood CD/MP3 player
Kenwood splits at the front.
Kenwood 6" cones at the rear.
2x 10" Alpine subs in box.
Schneider amps.
HICAS bar.
Also comes with:
Standard bonnet.
Standard pods.
Standard boot lid with Aftermarket carbon GT wing.
2x Standard spoiler and working LED lights.
HICAS unit
springs/shocks
rotors
Air box & snorkel
+ more.......
Tune:
205rwkw 10.5 psi
220rwkw 12.5 psi
1st and only track day I managed a 1:15.45 at wakefield park on Nankang street tyres running 12psi.
Price - $17,000
Located:
South Coast - NSW
Contact:
PM me through SAU
Email - p4mncwyz at dodo.com.au
Mobile - 0408417970 SMS only please (limited reception)
Serious Interest only please.
post-13684-1181828412_thumb.jpg post-13684-1181828485_thumb.jpg post-13684-1181828519_thumb.jpg post-13684-1181828543_thumb.jpg post-13684-1181828564_thumb.jpg post-13684-1181828582_thumb.jpg post-13684-1181828623_thumb.jpg post-13684-1181828638_thumb.jpg
  • 3 weeks later...
  • 2 months later...
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
