Hey Guys,
As the topic says id like to know what boost can be used on the track with the standard turbo R33 GTST safely? ie i dont wanna blow the ceramic turbine off the shaft, any comments and advice would be appreicated ,cheers
0.8 bar.. had no problems at the track day..
mods: full exhaust, pod.. thats it.. no other mods.. including still stock side mount..
It all depends how you look after your car and the current condition of it..
10psi as stated, i wouldnt go any further.
Otherwise after a few extended sessions your likely to kill the turbo due to heat.
It might be ok for one session @ .8bar, but try 3 or 4 track days (with 4-5 20min sessions) and see what happens, regardless of the condition, its going to die due to heat
Just on this issue... i'm looking at doing a track day on July 1st or second i forget which.. anyway i've recently had it tuned on 12psi... do i need a retune and does anyone know how to turn down my boost setting as i replaced the boost solinoid for a new one... all work was done by hi torque performance.
any advice would be great.
Hey guys,
Thanks for your posts Paul,Abo,Nismoid and siddr20.......i'll be getting a tune done to 10psi shortly, Nismoid you say its a question of heat are you sayin that for this particular turbo as it has a ceramic turbine? Also if heat is the issue do you think this could be overcome by water injection? Okay to make it clear we all know that the ceramic turbo disintergrates at high boost for long periods ie on the track , so the reason for my question is if it could run cooler at high boost would it prolong the life of it?
Yes because it has a ceramic turbine. It's the exhaust that's hot. Water injection cools the intake charge. More power = more heat.
I ran mine at 0.8 bar and went to about 10 track days. Then I went to another track day and blew the turbo on the 2nd lap.
sorry i meant to clarify i did have a turbotech bleed valve and obviously easy to change boost on that but now the new solinoid i have no idea... also does this mean i retune. not sure if i want to tempt fate with this or not. really don't have the money for a new turbo just yet... although soon, so kinda unsure which way to go
Yeah Abo,Nismoid
Okay i'll agree with more power=more heat , so why are Water injection sellers claiming it reduces the exhaust and combustion temps? Dont forget that adding the Water/Methanol mix increases the Octane rating of the fuel at high boost if that is where its used, higher octane fuel = slower burning.... less chance of detonation...wouldnt that reduce the temps but increase the combustion pressure over a longer time during the power stroke? hence more torque/power. just my thoughts, cheers
Restless
just ask your tuner to turn down your boost if he's worth his salt he'll do it for little or no cost.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
    • Wonder what the cause is, but here's hoping it's nothing too serious.
