Last night I popped out to Quix at about 10:30pm and when I got home and put my car in the garage I forgot to turn off the ignition and my car was idling in my garage until 6:30am :)
Usually I just turn ignition off and my turb timer shuts her down after 30secs-1min, but not last night...
It got hot but didnt boil (was pining this morning and running rough)
the garage was locked up so it was sucking down some nasty fumes all night, the entire car was hot aswel, ie the transmission tunnel etc.
so, anyone know if this is a realy bad no no and am I likely to have major problems.
she also drank about $30-$40 of fuel :)
cheers for any advise on this one
https://www.sau.com.au/forums/topic/172869-r32-gtr-long-time-idle-screwup/
thats sorta pretty funny... only cos I've amost done it myself.... :)
don't think it can really do to much to your car.... but I'm not a mechanic.
probably just hurt your pocket with the lost fuel more than anything.
hope all goes well.
Why leave it running. Its simply not needed.
Unless you drive flat stick for the last 1km to your house simply turn the car off just before you get out of the car, if you are in the habit of tearing down your street let it idle for 30secs and turn it off. 30secs is usually the time it takes for you to grab your wallet and take your setbelt off anyway.
The turbo's are now watercooled so thermosyphoning continues to cool the turbo when you shut the car down.
I've done this for the last 5.5years and travelled over 175,000km's and never had a turbo failure. Upon inspection of the turbo oil lines and turbo its self there is no oil coking. Use a good grp iv synthetic oil and you are less likely to have issues with oil coking.
I'd simply give it an oil and filter change. Prolonged idling isn't good for the oil or bores due to fuel dilution. Inspect the plugs they may be fouled from prolonged idling.
due for service and dyno now, but clutch is being fitted so I have to bed that in for 300k's before I put it on the rollers, so I spose I can wait another week or 2 before doing oil and filters?
and yeah I know turbo timers are overated but I have it set to 30 seconds only and as my garage is locked up at night I usually leave my keys in ignition, hence my screwup
the car was hot and pinging under light acceleration on mny way out the driveway, a bit of low speed crusing and temps dropped back to normal (my car seems to run quite hot on idle or in traffic at the best of times)
cheers, for the piece of mind tho guys, I was a little concerned that there would be potential issues with overcooking sensors and turbo oil seals etc...
do what those guys said above i suppose. also i was thinking of resetting your computer so that it learns from preschool how you drive and the environment it is in. it would of been sucking in all that low oxygenated air causing many many things as well, hence maybe your reason for pinging....
yep thats what ive herd aswell. personally im not a fan of idling, even when the car is cold in the mornings, just start it, get comfy, find a good radio station and go, usualy just keep it under 3000rpms until it gets to operating temp.
but you only left it on over night once, not like you do it every week, i wouldnt worry about it too much, maybe check/clean ur plugs...
I have heard mentioned before that prolonged idling can glaze the bores.. an engine builder or mechanic care to comment?
Prolonged idling will only glaze the bores if it hasn't been run in and or the mixtures are rich. BTW resetting the ECU will do absolutely f**k all. You may have a few carbon build ups within the chambers that is causing hot spots and leading to detonation. Put it this way the more it pings the less carbon there will be in the chamber but your bearing will get a hammering. Just give it a long light load drive and see if it comes up ok.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
