HI THERE,
JUST AFTER SOME PART NISSAN PART NUMBERS FOR A R32 GTR 90' MODEL.
1. THE RUBBER SEALS WHICH GO AROUND YOU ROCKER COVERS - PRESUME THEY MAY COME AS A KIT BUT COULD BE WRONG ON THAT ONE? AND
2. THE REAR GEARBOX RUBBER MOUNT, (HOLDS THE GEARBOX AT THE RIGHT HEIGHT BETWEEN WHERE THE BAR GOES ACROSS THE CAR IN THE MIDDLE AND THE BOTTOM OF THE REAR OF THE GEARBOX).
MANY THANKS IN ADVANCE!
ADRIAN. >_<
HI THERE,
ADRIAN. >_<
please look at this and tell me that these are the parts you need. i will supply you with part numbers if they are.post-14067-1186364698_thumb.jpg
i haven't been able to find the gearbox mounts. i do know that you can get the nismo 1s from justjap. Gearbox mounts
maybe arbess will be able to find the genuine 1s for you.
1990 R32 GTS4
drivers side propella shaft rubber boot (shaft to front diff housing)
Picture added to help clarify the part:
im not sure what part your after. i dont know of any rubber boots like that on the front driveshaft. steering rack maybe?
Yep, those are the two gaskets i'm chasing which you have highlighted in green would there be any chance you could get the part numbers for these that i have to go to Nissan with to order them direct - i was also going to chance the half moons whilst i was in there replacing the rocker gaskets - so the parts i'm chasing are:
1 x 13270
1 x 13270 + A
2 x 11051H
I'll also grab that gearbox mount from justjap so thankyou very much for the link to that page, it's greatly appreciated!
Many Thanks,
Adrian aka skysaresilver
1 x 13270
1 x 13270 + A
2 x 11051H
Many Thanks,
1 x 13270 = 13270-58S01-
1 x 13270 + A = 13270-58S11-
2 x 11051H = 11051-58S00-
>_<
hey mate
just after part numbers for R32 gtst 93
idler pulley
tensioner pulley
water pump
timing belt
are these part numbers the same as a r33 cause i've heard they are the same
thanx
21010-70T25 - RB20DET water pump (or try 21010-42L25)
13028-20P25 - RB20DET timing belt
13074-58S00 - RB20DET idler pulley
13070-53L00 - RB20DET tensioner pulley (or try 13070-73L00)
Water pump is approx $110 retail from Nissan
You are better off getting some Gates or CBC bearings/pulleys as OEM you can expect to pay $250+ for each
Autobarn for eg, can order in a kit for you fairly cheap and it also includes the oil seals, but CBC bearings are better quality and a little more expensive (still cheaper than Nissan though)
Also the Gates Racing timing belts are about the same price as a standard OEM belt
Are you doing the 100k service?
you are a legend :P
I'm trying to find a noise and had to take my balancer off in the process so i thought I might aswell do it again. maybe if i'm lucky it will get rid of the noise too.
nah not going to nissan. bearing industries couldn't find the part number for rb20's.
thanx heaps :thanks:
thanks mate for the info.. :D
No probs. ;)
need part number for a o2 sensor for a '95 model series 2 rb25det?
R33 RB25DET 02 sensor part numbers:
08/1993 - 11/1993 number : 22690-21U00 (alt number 22690-83T10)
11/1993 - 01/1996 number : 22690-83T10
01/1996 - 11/1997 number : 22690-83T10 (same)
11/1997 - number : 22690-83T11
Edited by FighterJoe
Excellent thread! :D
I need some help also for the following:
1996 R33 GTR
BCNR33-024671
Injector sealing O-rings
Intake Plenum Gasket
AAC Valve Gasket (maybe the same as this? 23785-40F00)
Driver Door Seal
Passenger Door Seal
And finally... the little GTR Square plug that goes by the coin holder on the center console behind the shifter boot.
Thanks in advance. ;)
David.
1996 R33 GTR
BCNR33-024671
Driver Door Seal
Passenger Door Seal
David.
For BCNR33-024671 (Nov 1996)
Injector sealing O-rings - Insulator-injector number: 16636-V5000
Intake Plenum Gasket - Intake manifold gasket number: 14035-05U10 (assuming intake manifold gasket not throttle chamber gasket which is 16175-05U70)
AAC Valve Gasket (maybe the same as this? 23785-40F00) - AAC gasket number: 23785-40F00 (yep same as the one you quoted)
Driver Door Seal - Right hand door weather strip number: 80830-22U00
Passenger Door Seal - Left hand door weather strip number: 80831-22U00
the little GTR Square plug that goes by the coin holder on the center console behind the shifter boot - Switch hole mask number: 68960-24U00
Hey just me again,
Thanks once again for the part no's you were able to get for me last week they were tops and i ordered and fitted the parts from Nissan on the weekend!
Just another quick question for the Injector Sealing O-rings are they the same part on the r33 gtr as on the r32 gtr, (16636-V5000) or another no altogether, and are they the seal between the fuel rail and the injector head? As that's the part i'm after!
Many Thanks once again,
All your help here with Part #'s is excellent!
skysaresilver
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
