Nissan Genuine Part Numbers
arbess
umm not true, at least not for my 32 gtr's vin#. I can check for yours if you like - just send the vin
Front turbo oil return hose 15198-05U04
Rear turbo oil return hose 15198-05U13
they are *very* similar but not identical. Front has one end about 5mm longer. I'm sure you could use interchangeably without trouble though
the handbrake is a single piece, that part is everything except the bracket that bolts to the car.
not sure which nissan dealer to use in vic, and it is unlikely they will have one in stock anyway. You are much better to order from Japan via Slide will be about 60% of nissan's price and the same wait
Hey all. Just wondering if there is a part number for the tacho modual in a R33gtst series 1 1995 dash cluster. I want to replace the tacho unit in my cluster. Trying to work out if cheaper to buy new modual part (which i doubt), or just buy a second hand cluster n mix n match parts?
Can you attually just buy the tacho gauge?
assy is short for assembly. So its an o2 sensor assembly
Cool, sorry for the noob question, by the way i got my Nissan original o2 sensor today, looking good, didnt have time to replace it yet tho..
    • I use the flattest and most level piece of concrete I have. And then I shim the tyres on the low side of that with sheets of plywood to level the car. The right amount is easily found with a 2m straight edge and a level or digital angle finder. I use both the spirit level and the same digital angle finder I use to measure the camber. Gives a zero check on the angle finder right at the start.
    • Hi guys,  I'm chasing a recommendation for a turbo charger to suit 600whp.  Engine is a RB25 series 2, with rebuilt forged internals with 8.5 comp ratio. Cams are 262/272. I was considering buying a Garrett G30 770 with 0.83 AR, would it be best to get a V band inlet and outlet to suit as I need to buy a 6 boost manifold as well? Thank you.
    • Hey Duncan,  What you did with the boot is mint, I'm going to do the same with my R33.  Do you no longer like the R-Chassis?
    • Just keep in mind (maybe too late now) that before you go crazy, most driveways aren't flat. This _can_ affect your dynamic camber and heights too. It is kinda funny but getting people to really align stuff right can be problematic for people with OCD. Consider a motorsport place if there's any around, and also consider you may have 'dynamically' altered your own camber after a visit to the track, which can happen too.
    • So I got some fresh Kuhmo 275's on the back to replace the crap that came on this set of wheels and put them on with the front street'ers too. But man I was getting crazy rubbage on the rear passenger side which is odd as the previous crap was 275 also and was on there before I added my extra camber. The semi's are also a *fat* 265 and had no rubbing. I noticed that the camber left and right was pretty different. Very little on the passenger side. My magnetic camber tester on uneven ground showed roughly -1.75 on drivers side and less than -.5 on the passenger side.   It would have been like this on the track day. :( I adjusted the passenger arms to be as close to the drivers as I could get by eye. I then used my new fender roller to make some extra space but holy crap the folds on the guards are made from battleship steel! I couldn't get much rolled at all, they were so strong. My alignment is now off with a 30 degree turn in my steering wheel. I'll find a new alignment joint I think. Not only did the last place think my speed sensor cable zip tied to the camber arm was a brake line, they didn't zip tie them back after they aligned it which was pretty poor. Happy I noticed and did it before the track. Looks like they couldn't match left and right either.   Gave the old girl a bath and I'm always so happy with how she polishes up.
