ahh well at least its in a nissan box not an ntk one. how much did they rape you for that?
there are aftermarket ones with the correct plugs that are direct plug in replacements.
:) its say NGK on the actual sensor...........got it for $168 something with GST, I asked here several times if those NTK or Falcon ones gona be ok for my GTS4 non-turbo, the answer was yes, when i calld NGK directly about this, they advised me it wont be 100% accurate so asked to get original one ;) was paranoid about getting NTK after that
well I think I should have gone for NTK one tho (like$70 i think),,, oooh well
Note- got a OEM oil filter from NIssan while I was there, well they are not really genuine I guess, its made in Thailand.............I love stuff from Japan :)
Hey all. Just wondering if there is a part number for the tacho modual in a R33gtst series 1 1995 dash cluster. I want to replace the tacho unit in my cluster. Trying to work out if cheaper to buy new modual part (which i doubt), or just buy a second hand cluster n mix n match parts?
Can you attually just buy the tacho gauge?
part No# 24825 21u01. tacho meter only
hey guys. Need help with part numbers.
I have checked everywhere in nissan fast i can think of and havent had any luck.
Its the metal thing covered in plastic that goes on the doors just below where the window starts (see picture....the thing circled in yellow)
For 1990 r32 gtst
vin HCR32064384
Need the part number for each side.
cheers guys
looks like 80820-04U00(RH) and 80821-04U00 (LH) "moulding assy front door outside"
there is another part 80834-04U00 (RH) and 80835-04U00 (LH) "weatherstrip-front door inside". I think that is between the trim and the window though.
Looks like 80820-04U00(RH) and 80821-04U00 (LH) "moulding assy front door outside"
Thats the one. Awesome work Duncan....cant believe i missed it :(
i know this will be hard to find i would imagine but im after the part no. for a brake master cylinder from a wgnc34 autech 260rs stagea series 1 if possible (i think s1, and s2 is the same)?
i have 34 brembos on the stagea and need a brake booster to suit but i found out 33gtr and 34gtr use different masters i cant see why if they are the same brakes? hopefully the autech one will be the correct one.
thanks
If you have the r34 brembos fitted, wouldnt you be able to use the r34 brake master cylinder? im havin a little difficulty with fast so i cant check right now but im workin on it now. somebody else out there with fast might be able to post up the number before i get around to it.
"it would be easier and cheaper to get after market 1s. google r34 eyelids or use the search button at the top here."
tried the search and majority of em are DIY or from carmate. AFAIK, aftermarket ones are approx 120ish after paiting whereas the nismo ones are around150++. Would rather get nismo in this case
Do you know where can we get nismo eyelids?
thanks mate, i am just wanting to make sure the brake lines all line up with the 34 master thats all, its rather expensive to get it wrong ($300 or so), i cant see why the 34 and 33 would be different?
When i can get fast working ill have a look for a part number. not promising that it will be there though. you could try calling a Nissan dealership and speaking with spare parts. They may be able to help you. If not, try searching yahoo japan auctions. there is several ways to buy from there including Slidewize performance I bought from Zac a few times. always delivered what ive bought. Theres other companies out there that can buy from the auctions on your behalf.
Yea expenses suck. There could be numerous master cylinders that will line up. Maybe best speaking with a mechanic. You might be able to find a cheaper alternative to the R34 1. Ill try to find the number when fast is working.
thanks
Sorry for the inconvenience but its been ages since ive used fast and i have actually never looked for stageas before. can you make it easier and supply me with a vin number? that saves me a lot of stuffing around
ive had a look but i haven't been able to find it. maybe someone else that has fast would be able to track it down.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
