part NO. 80570-91L00 same for both sides. by the way they call it a door stiker
Thanks
VIN:GGKBRTFR33VDAAALCC....I THINK thats my vin :P
Id also like the part number for the ruber seals around the door handles.
And complete rear boot mechanism
Thanks
VIN:GGKBRTFR33VDAAALCC....I THINK thats my vin :(
first of all i did a bit of a typo there It' striker (not stiker)
now for some bad news. thats not your vin it will be on the firewall should go somthing like ECR33-(six numbers)
by the looks of things nissan do not sell the rubber seals around the door handle's seperately. get one with every handle by the looks.
boot latch 84630-15U00
I am chasing a part number for the rubber gasket between the 2 halves of the plenum for an R33 Gtst 1997 series 2, or a suitable substitute.
Many thanks
Peter
Gasket between plenum and intake Part No. 14032-75T05.
please look at this and tell me that these are the parts you need. i will supply you with part numbers if they are.post-14067-1186364698_thumb.jpg
i haven't been able to find the gearbox mounts. i do know that you can get the nismo 1s from justjap. Gearbox mounts
maybe arbess will be able to find the genuine 1s for you.
Part number for that seal on the tappet cover that the hold down bolts go through. Item 12364D
May I ask for the part numbers below ?
1.R32 GTS-T RB20DET hcr32
Headgasket
Full engine gasket kit
2.R33 GTS-T RB25DET ecr33
Headgasket
3.R34 GTT RB25DET NEO er34
Headgasket
4.R32/33 GT-R RB26DETT bnr32/bcnr33
Headgasket
Really appreciate it ! Thanks!
Headgasket
Headgasket
Headgasket
Headgasket
we are gonna have to know a estimated year model for each of these, R32 are fairly staight forward. but R33/R34 change headgaskets and engine gasket kits depending on a few things like year model. e.g R33 from 09/97 use the same headgasket as a R34 in the RB25
at least but are different before that
r32 - 93
r33 - before facelift 93-95 ?
r34 - 99 ?
1990 bnr32 RB26DETT
If someone could help me out with the part number or even just the name of the:
clips/plugs that hold the plastic cover across the lower portion of the front windscreen (just below the wipers)
- I think there is around 6 of the plugs -
Thanks in advance,
Dan
Was wondering, im trying to find out what models use the same coil packs and igniter module as mine, here is the result after loading in my vin for the igniter:
Does it mean that every part number listed there will work on my car?
here is another one which is coils, used the vin method again and the part number came up as 22448-o2u11-
In this pic does everything with that part number mean i can use it?
And also in that pic notice the mention of a RB26DTT, not DETT, which would mean a carbie fed rb26, maybe a typo?
Edited by W0rp3D
Are you sure you entered the VIN correctly, as it's coming up with R32 as the series.
Anyway, when theres multiple parts presented look at the "From" and Up To" columns and they tell which model years the part is for.
yeah, then i went into the r32 section to see if there was any in there with the same part number as it spat out for me, which it seems the same part number was also used for all the rb engines apart from the rb20e.
Well R32's use same coilpacks as your r33 s1.
Sticking my VIN into fast i get:
coilpack assembly - 22448-02U11
id like a part number for the front glass-windshield for a nissan skyline R33 jap vin ECR33-053444..
Also, has anyone ever changed theirs? and how much did u pay?
Cheers.
ecr33 front windshield - 72712-24U00
Just trying to figure out what i can use, limits it a bit if im only looking for something of my car, but if i can cover all off r32's as well then it makes it easier to find parts.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
