Hi
Can you please find numbers for all breather hoses on/around rocker covers RB20det HCR32.
Cheers
not sure if these are the only ones you need but.
11826-04U10
11826-72L10
11826-73L10
they are onto LH rocker cover, then to from LH to RH rocker cover, then RH rocker cover to inlet plenum
Hey there guys im just chasing order numbers or part codes for:
1995 series 1.5 R33 2 door coupe - Drivers side window surround.
1994 series 1 R33 4 door - Lower sealt belt pillar cover.
  • 4 weeks later...
Hi, just wondering if you know the part numbers for a front bumper support for my 2000 4 door GTT , i think its a series II
im after the middle and 2 side supports , they sit right behind the front bumper
and also if you can tell me how i might get my hands on some ....
i rang nissan ...was no good
thanks
Hi,
Im trying to find the part numbers for the R32 GTR bonnet lip, and N1 vents for the front bar (right and left) in gun metal grey. I appreciate that this info is in this thread somewhere but the search function is non functional at the moment and Ive looked through the thread manully with no sucsess. Any assistance is much appreciated.
Cheers, Sandy.
hey got a R32 Gts-t coupe is there a gasket 4 the fuel pump and if there is i'd like to know the part number please also the number for a rear diff pinion seal?
is there numbers for tie rod ends? R/H/F if that makes any difference?
yeah nice thread keep up the good work Thanks
Hi,
Cheers, Sandy.
N1 bonnet moulding part No. 65820-06U25/ f5820-05U00
may have been replace by latter No.
Rh bar vent 62256-05U08
LH bar vent 62257-05U08
Fuel tank sender unit/pump seal 17342-01A00
pinion seal working on r32 08/91-02/93 with hicas, RB20det. part No. 38189-N3111 (there are also 3 other option so need more info)
RHF tie rod end part No. 48520-71L25. for 2wd
in ending more info is needed for correct info
Edited by neofenrir34
Does anyone have the Part Numbers for the following:
R34 GTR with brushed silver dash -
* Ashtray
* Stereo Fascia surround
These numbers suit 08/00 onwards (get local nissan dealer to send a parts query to find out if they are silver)
Stereo surround 68260-AB100
Ashtray 68800-AB100
* Ashtray
Ashtray 68800-AB100
thanks
not sure if these are wat u are trying to explain but
62216-AA010
62217-AA010
ref picture.
try your local dealer again they where most likely to lazy to look the part up
1993 R32 GTs-T RB20DET with hicas (diff is a LSD)
model number: HCR32-290387
but thanks man :P
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
