Nissan Genuine Part Numbers
arbess
Hi
Can you please find numbers for all breather hoses on/around rocker covers RB20det HCR32.
Cheers
not sure if these are the only ones you need but.
11826-04U10
11826-72L10
11826-73L10
they are onto LH rocker cover, then to from LH to RH rocker cover, then RH rocker cover to inlet plenum
11826-04U10
11826-72L10
11826-73L10
Thankyou Very Much!
Hey there guys im just chasing order numbers or part codes for:
1995 series 1.5 R33 2 door coupe - Drivers side window surround.
1994 series 1 R33 4 door - Lower sealt belt pillar cover.
  • 4 weeks later...
Hi, just wondering if you know the part numbers for a front bumper support for my 2000 4 door GTT , i think its a series II
im after the middle and 2 side supports , they sit right behind the front bumper
and also if you can tell me how i might get my hands on some ....
i rang nissan ...was no good
thanks
Hi,
Im trying to find the part numbers for the R32 GTR bonnet lip, and N1 vents for the front bar (right and left) in gun metal grey. I appreciate that this info is in this thread somewhere but the search function is non functional at the moment and Ive looked through the thread manully with no sucsess. Any assistance is much appreciated.
Cheers, Sandy.
hey got a R32 Gts-t coupe is there a gasket 4 the fuel pump and if there is i'd like to know the part number please also the number for a rear diff pinion seal?
is there numbers for tie rod ends? R/H/F if that makes any difference?
yeah nice thread keep up the good work Thanks
Hi,
Cheers, Sandy.
N1 bonnet moulding part No. 65820-06U25/ f5820-05U00
may have been replace by latter No.
Rh bar vent 62256-05U08
LH bar vent 62257-05U08
Fuel tank sender unit/pump seal 17342-01A00
pinion seal working on r32 08/91-02/93 with hicas, RB20det. part No. 38189-N3111 (there are also 3 other option so need more info)
RHF tie rod end part No. 48520-71L25. for 2wd
in ending more info is needed for correct info
Edited by neofenrir34
Does anyone have the Part Numbers for the following:
R34 GTR with brushed silver dash -
* Ashtray
* Stereo Fascia surround
These numbers suit 08/00 onwards (get local nissan dealer to send a parts query to find out if they are silver)
Stereo surround 68260-AB100
Ashtray 68800-AB100
* Ashtray
Ashtray 68800-AB100
thanks
not sure if these are wat u are trying to explain but
62216-AA010
62217-AA010
ref picture.
try your local dealer again they where most likely to lazy to look the part up
1993 R32 GTs-T RB20DET with hicas (diff is a LSD)
model number: HCR32-290387
but thanks man :P
Looking for the part number for the water pump on a R34 RB25DE Neo
I mainly want to know if its the same pump used in my engine as in a 33 RB25DE(T)
