Looking for some trim parts for my S15. Looking for the outer door trim that sits on the top of the metal door and has the end that has a bracket that is screwed to the door itself. I need both Left anf Right.
Next is the metal track that runs perpendicular and sits in front of the quarter glasses and is the housing for the rubber seals. I need both sides in those as well.
Lastly, I need all the rubber sealing that fits around the door on the body of the car, not the door, that seals the door to the body of the car. I already have the door rubbers that attach to the door but not the one that attaches to the body. Can anyone help me please as I need these urgently.
If I can get pictures I can confirm. I also need these small items shipped to me in Trinidad in the Caribbean, postal code is TT. If they can be had used as well I am interested as I need them urgently please.
Jason.
Jason.
for the first ones ( door belt moulds ) part No.
80820-85F10 RH
80821-85F10 LH
for the second request i am not to sure the first to No. are retainers that look to hold the top door weather strip. and the seconed No. look to hold the QTR glass it's self
76872-85F00 RH
76873-85F00 LH
82328-92F00 RH
82329-92F00 LH
and for your final request i would need to know more info on your car. I can't help u with shipping or prices, sorry
80820-85F10 RH
80821-85F10 LH
76872-85F00 RH
76873-85F00 LH
82328-92F00 RH
82329-92F00 LH
Thanks again.
Hi Guys
Forgive the idiotic nubi question, but I'm looking for the part number for a '00 R34 GTT (RB25DET Neo) Engine Loom..
If there are multiple part numbers is it possible to get a listing?
Thanks..
Hi Guys
Thanks..
what parts do u need for tis engine wiring loom because there are about 3 looms that do all of the engine bay. and more info would help like a vin number
hey,
do you guys have the part number for the studs and nuts
R32GTR
1. Turbo to dump pipe
2. Turbo to exhaust manifold
is there a part number for a turbo gasket kit
there is a gasket kit Part No. 14401-05U25
If it helps, from what I have been told I need them all, as the car is a NA+T transplant. VIN number won;t be much use as the car is originally a NA and this is to a stock Turbo ECU that is being attempted to get working right :down:
Hence would need part numbers for the stock turbo gear from any 34 GTT, the more the merrier.
  • 4 weeks later...
Hi there,
Can someone help me out with part numbers for:
R33 GTR bonnet hinges; left and right.
R33 GTR bonnet catch/upright.
R33 GTR guard raiser brackets; left and right.
Having a bit of trouble finding these locally so am looking at sourcing them from Japan.
Thanks,
Rob.
Hi can i get the part numbers for:
r34 xenon drivers side headlight
r34 gtr bonnet, fenders left hand and right handside,
thanks.
does anyone know where i can get these parts other than nissan genuine, they keep bothering me about these part/model numbers
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
