  • 3 weeks later...
Bit of a small thing but need the number for the standard speaker covers for the rear speakers in my series 2 r34 GTT (unsure if different to series 1 have been told they are)
28174-5P600 RH
28175-5p600 LH
those should be close, however being a trim part i would prefer to have a vin number
Does anybody knows the part numbers from:
R34 GTR Front Bumper V-spec
And the optional lip
Also the R34 GTR Front bonnet V-spec
And Front fenders from R34 GTR.
Thank you all!
Akis.
Front bar F2022-AA4MD
Front lip 96015-AA440
Bonnet F5100-AA4MM
Fender RH 63112-AA430
Fender LH 63113-AA430
Need part number for 1990 RB26 non n1 waterpump..
Searched but i have found like 3 - 4 different part numbers!
I think 21010-58S25- may be correct can someone confirm for me?
21010-58S25 is a good number for R32 RB26DETT engine
urgently need the part number for the seal between the injector rail and injector intake.
much appreciated if someone could help me out.
cheers.
please confirm if highlighted part is correct?? (poor description)
Does anyone have the part number for R34 GTR front fenders? Looking at doing a GTR front end conversion on my 4 door 34. Thanks.
please refer previous post about GT-R vspec fenders, bonnet and front bar. guard part NO. are the same
hi i'm after the headlight switch on the side of the gauge cluster (have the one headlight problem, pulled it apart but it's totally screwed) :)
bnr32
1992
model: KBNR32RXFS AA
chassis: BNR32-221349
thanks
did some searching came up with this:
25160-01U00- Switch Assy - Lighting no
can anyone confirm?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
