Hey guys,
was wondering if anyone could help me in finding out what model skyline these part numbers came in.
38220-0V770
38220-0V771
diff flange's.
reason being i apparently need these as i am putting a OS giken diff in my 34GTT which has the VLSD. these are not on file in nissan aust, and i would have to get from japan,
was hoping i might be able to get something from a factory diff!!
Any help would be appreciated!!
Pinion Seal 38189-N3112
Pinion Bearing 38120-13210
Oil Seal Side 38342-P9010 x2
Bearing Side 38440-N3110 x2
Gasket 38320-40F02
It looks like the bearings would have to be ordered from Japan. Stock of seals and gasket in Australia.
  • 1 month later...
Hey Guys and Girls,
Just going to change all of the Drive Belts on my Series 2 R33 1995 GTS-T (RB25DET) and was wondering about the 4PK and 3PK part numbers (generic brand).
Does anyone know the cross reference from Nissan Part Numbers to Generic Brand?
My Nissan Numbers are
Fan Belt - N/11720 42L02AU
P/S Belt - N/11950 58S02
A/C Belt - N11720 77A01
Would love the generic numbers as it will save at least 50% in cost
Stephen
  • 1 month later...
Plastic winow visors/shields all 4
U shaped vacuum hose betweeen the rocker covers
Valve seals
Weather Shields? If so they are an accessory and need to be made specialy, they never really make them anymore (maybe even not available) so you would need like $800 so lets hope its not weather shields.
U-shaped hose ontop of cover, 11826-75T10 is $25(Ordered one for my car and got it 2 days ago so "in stock" but i need it really so there B/O Japan)
Oil seals are 13207-84A00 are $7ea (In stock in sydney warehouse so overnight)
In desperate need or left hand rear wheel bearing for the following:
VIN: WGNC34 127902
Model: TGKPREFC34UDA--A--
Prod: 9903
It's a 99 Stagea RS Four S (Factory Manual)
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
