  • 1 month later...
  • 1 month later...
Look for r33 door handle surround. Piece behind the door Handle interior mine broke when I took them off thank you!
If you mean what I think you mean then these should be right. Not sure about interior colour though. They are the same for front and rear doors for a sedan as well.
ESCUTCHEON-INSIDE HANDLE LH - 80683-70T02
ESCUTCHEON-INSIDE HANDLE RH - 80682-70T02
  • 4 weeks later...
er34-031157
GGKBRTFR34UDA-JJ-F
5/2000
Needing part number for
coolant overflow bottle cap
and on the oil cap.. if the seal comes seperate or part number for the whole cap!
Muchly appreciated!!
er34-031157
GGKBRTFR34UDA-JJ-F
5/2000
Coolant overflow bottle cap 21712-50M01-
Oil cap 15255-1P103-
13276-4P100-
hi
i was wondering if you can give me the part number for the oil filter housing on a rb20det for an r32
also for a remote control key for an r34 gt-t
thanks
steve
Oil filter bracket
15238-80S00-
Gasket
15239-71L00-
Remote control key
H0564-C9920- ??????
  • 3 weeks later...
  • 3 weeks later...
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
    • I'm looking for a direct bolt on turbo upgrade for my 93 R33 GTST.  Anyone have experience with this Greddy T620Z turbo upgrade? I'd like to be able to run about 300hp to the rear wheels without putting too much strain on the turbo. I do daily drive the car.  Pretty stock car with basic bolt ons (exhaust outlet, down pipe, high flow cat and catback exhaust along with intake and FMIC).  I'l probably have a Haltech plug n play on the car before installing the turbo. https://www.greddy.com/products/turbo-upgrade-ecr33-er34-t620z-rb25-11520057   Also, any thought on this much boost on a 30 year old motor with 250,000KMs?  Engine feels/sounds strong for what it's worth.   Thanks you in advance!
