I know this is currently a thread for genuine part numbers but I was thinking that is may help a lot of people to add aftermarket equivalents for some of the not-so-critical items, ie fanbelts etc.
Just incase you think it is worth while I'll add the Gates equivalent accesory belts for an R33 GTST.
Belt Desc Standard Part no. Gates Part No.
ALT/WP Belt 4PK850 4PK850
PS Belt 3PK845 3PK835
AC Belt 4PK910 4PK915
These numbers aren't the actual Nissan part numbers but refer to the belt dimensions, I think it is written on them.
For those who don't know, when talking about automotive Micro-V Belts the part numbers I have given above mean the following:
4PK850
4 - 4 Ribs (V's)
K - Belt Pitch (distance between teeth)
850 - Length of Belt in mm.
This should work for all aftermarket micro-v's regardless of brand. Like above if they don't have the exact matching number you can get away with the next nearest size depending on the amount of takeup left.
Edited by Fry_33
lol why is LH $100 more expensive.
Prices are based on quantity sold. Prob sold a couple more RH then left.
Same applies to a new model car. Parts start off exp and the more that are sold then the cheaper they get. Once the products start to not sell so much price will go back up again lol funny i know.
This heap of sh!t below is the "Mode Door Actuator". It if from an R32 GT-R & resides in the drivers side footwell on the left behind the trim panel that sits below the instrument cluster.
Anyway is there a part number & how much is it? Because I am sick of have no mode door actuation. :P
Thanks in advance. ;)
Anyway is there a part number & how much is it? Because I am sick of have no mode door actuation. ;)
Thanks in advance. :)
I would shop around for the mode door actuator. I have replaced mine with a brand new genuine 1 from Nissan and the price difference between dealerships is huge! the highest i was quoted was around the $460 mark yet i paid $189 for mine. I recently changed my OS to Linux and haven't been able to look up anything in FAST. i have the part details recorded in my word doc that i keep on my car but i seam to have misplaced this file! :)
I got basics on these 2 hoses, need to know price and availability asap!
15192ra
15192r
model, R32 GTR
section number if your using the cat system, 144 e02
They are coolant lines from the turbos and they arc up and meet in the middle above the turbos can also fax pictures from the cat system if needed.
Really need these asap
Cheers, Mick
15192ra
15192r
model, R32 GTR
Cheers, Mick
If you require these asap, id suggest you grab the phone book and call your closest Nissan dealership.
This thread is for part numbers only and parts arn't sold here. There are some members on here that do work for Nissan and may be able to give you a price but i dunno if they could supply them for you.
Cheers.
you sure can, but I don't have the part number. The insurance company paid for new seals for mine when the rear screen was broken. $0 excess. from memory the seals were about $500
Ok, Fast Guru's, I got some part numbers that I would like confirmed if possible.
Its for a 96 R33 GTR, you can see the vin in my id info.
Can you confirm:
13270-58S01 - Gasket set for Valve Covers (contains 2x valve cvr gaskets, 2x half moon gaskets, 20x grommets)
24079-84T00 - Coil pack harness from ign amplifier to coils (I broke the plastic locking tab on #3 coil plug)
23731-02U11 - CAS
edit: Ok, found out that the bold part number is only for one side of the valve cover, can anyone confirm if these are for the Half moon gaskets?
Cam Half Moon Seals x2: 11051-58S00
Thanks guys.
David.
Edited by i4dat
R32 GTS-T
Tensioner spring - part # - 13072 58S10 $3.03
Sump plug - part # - 11128 01M05 $2.53
Sump plug washer - part # - 15193 P9000 $1.40
Tensioner spring is for cam belt tensioner pulley.
Dammn p9000's are only 80c at out work retail :O which dealer sold it to you for that price? lol
Rex Gorrell Nissan, Geelong. I don't think i'll worry about the extra 60c. :rofl: Hardly worth shopping around for............
Looking for part number for these.
1: The boot garnish, as in the plastic part that is on the rear of the boot where the boot clip is. Held on by those plastic plugs that break.
2: Center Console cover, Whole plastic item that is around the cd player clock ect.
3: Power Window button garnish mines faded and worn.
These are all for Series 1 R33 1993
Also keen to know this, I can see me breaking it trying to take it off, has a crack already from previous owner installing a deck.
OK Part number gurus, I need the part number for the loom that sites next to the oil filter on an rb26, has 2 knock sensors attached, oil temp and aac plugs among others.
Looks like 24079-05U01, can anyone confirm before I order it? Vin# is BNR32-014400.
