Hmmm. I spoke to Nissan and they said that they couldn't order just the seals, and I would have to buy the window kit (about $480 a pop). Urgh. Anybody have any ideas? :)
yep that is correct. quarter windows are bonded to the seals no real way around it. :woot:
yep that is correct. quarter windows are bonded to the seals no real way around it. :)
Thanks Richard. That's awful: my current windows and seals are fine, the seals just look a bit crappy because they have lost their shine in patches.
me too mate. :) I went genuine for door seals, rear screen seal and front screen seal and mold kit. and after the bill over well over $1000 for that lot I couldn't really stomach another $1000 for the 2 quarter windows. one day I probably will though.
  • 3 weeks later...
This will look a little plain but as soon as i can get some general parts together I will list them.
check back soon
R32
***GT-R***
Engine
- Belt | Fan & Alternator AY140-40880-
- Belt | Compressor AY140-40925-
- Belt | Power Steering AY140-40950-
- Belt | Timing 13028-20P25-
- Clutch | Disc 89 to 93 Feb 30100-05U00-
- Clutch | Disc 93 Feb Onwards 30100-12U00-
- Clutch | Cover 89 to 93 Feb 30210-05U01-
- Clutch | Cover 93 Feb Onwards 30210-12U00-
- Clutch | Release Bearing 89 to 93 Feb 30502-21000-
- Clutch | Release Bearing 93 Onwards 30502-12U00-
- Clutch | Booster 30630-05U01- Around $180.00 - Nissan 2007
- Element | Air AY120-NS001-
- Filter | Oil AY100-NS007-
- Pump | Water Pump Assembly 21010-58S25-
- Pump | Oil Pump
1989 Aug to 1993 Nov 15010-05U10-
1993 Nov Onwards 15010-05U11-
- Sensor | Oil Pressure 25070-30P00-
- Strainer | Fuel 16400-72L00-
- Thermostat | Water 21200-42L05-
Chassis
- Brake | Kit for 89 to 93 Feb AY040-NS003-
- Brake | Request Kit for V-Spec /II
- Shaft | Front Drive RH 39100-23U00-
- Shaft | Front Drive LH 39101-23U00-
- Shaft | Rear Propeller 37300-05U00-
- Steering | Power Steering Rack 49001-05U00-
- Steering | Rack Request for V-Spec /II
Exterior
* Request for colours other than KH2 Gun Grey
- Air Spoiler | Front (Lip) 96015-05U00-
- Air Spoiler | Rear Kit (Unknown Colour) 96030-05U00-
- Boot | Lid (Unknown Colour) 84300-04U30-
- Front Grille KH2 (Gun Grey) 62310-05U03-
- Spoiler | NISMO (Boot Lip) K6032-06U00-
Interior
- Heater & Blower Unit | Actuator Assembly - Mode 27731-53E00-
- Finisher | Right (Rear Quarter window Surround) 2 Door 76934-04U00
- Finisher | Left (Rear Quarter window Surround) 2 Door 76935-04U00
Electrical
- Ignition Unit All years 22020-05U00-
- Coil | Singular 89 to 92 Aug 22448-02U10-
- Coil | Singular 92 Aug Onwards 22448-02U11-
- Engine Management (ECU)
08/89 to 11/90 = 23710-05U02-
11/90 to 08/91 = 23710-05U03-
08/91 to 04/92 = 23710-05U60-
04/92 to 02/93 = 23710-05U61-
02/93 onwards = 23710-05U62-
Cables
- Speedo Cable Manual Transmission 25050-05U00-
GTS-T
Cables
- Speedo Cable Manual Transmission 25050-02U00-
- Speedo Cable Automatic Transmission 25050-03U00-
Engine
- AAC Valve Gasket 23785-40F00-
COMPATIBLE ITEMS
Spark Plugs are universal throughout GTR/GTST Please ask for RB20DE or any other variations
Model Years: 89 Onwards Spec Code: PFR5A-11[b512] RB20DE +RB20DET +RB26DETT HEAT RANGE 5
Model Years: 89 Onwards Spec Code: PFR6A-11[b512] RB20DE +RB20DET +RB26DETT HEAT RANGE 6
Model Years: 89 Onwards Spec Code: PFR7A-11[b512] RB20DE +RB20DET +RB26DETT HEAT RANGE 7
Electrical
- Heater & Blower Unit | Actuator Air Mix 27742-77S60-
- Heater & Blower Unit | Actuator Air Mix Kit 27732-01U00-
Can i get the same rundown but for R32 GTS-t???
Cheers Ben
1994 R33 GTS4 (RB25DE NON-TURBO)
Vin - ENR33002946
Looking for part numbers.
O2 Sensor --
Thermostat --
Cheers
Note - what is a good after market Thermostat , I want a normal one not a low temp one. a plcae to buy in sydney?
Vin - ENR33002946
O2 Sensor --
Thermostat --
Cheers
1994 R33 GTS4 (RB25DE) NON-TURBO (Vin - ENR33002946)
Thermostat - 21200-42L06-------------($47.80 from Lander Nissan Blacktown)
Fan belt - 11720-42L02AU----------($34.30 from Lander Nissan Blacktown)
Power steering belt - 11950-58S08----($37.09 from Lander Nissan Blacktown)
FAn&Alternator - 11720-77A01----($38.01 from Lander Nissan Blacktown)
o2 sensor?
I'm in need of the part number for an R32 GTR (1992 model) RB26DETT air intake temp sensor (sits on the intake manifold towards the front)
u sure it is a air intake sensor. fast calls it a coolant temp sensor part NO.22630-01u00. it is the part at front on intake with the 2263j label
Doc2.doc
Edited by neofenrir34
yeah thats the right part number and its definately an intake air temp sensor not coolant. wierd - i've seen some strange descriptions but never a wrong one before. Unless that part was used as a coolant sensor in 01U (whatever that was) and an air sensor in 05U (gtr)
That part number is correct. Thanks for that.
$65 trade from Nissan.
The part number for an R32 GTR (RB26DETT) oil drain hose (from the turbo drain to the block) is 1519805u04
There are 2 of these and although they look different to one another on the motor, when you remove them, they are exactly the same (thus the same part number)
These cost me $40 each trade :ninja:
Greg
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
