ahh well at least its in a nissan box not an ntk one. how much did they rape you for that?
there are aftermarket ones with the correct plugs that are direct plug in replacements.
:) its say NGK on the actual sensor...........got it for $168 something with GST, I asked here several times if those NTK or Falcon ones gona be ok for my GTS4 non-turbo, the answer was yes, when i calld NGK directly about this, they advised me it wont be 100% accurate so asked to get original one ;) was paranoid about getting NTK after that
well I think I should have gone for NTK one tho (like$70 i think),,, oooh well
Note- got a OEM oil filter from NIssan while I was there, well they are not really genuine I guess, its made in Thailand.............I love stuff from Japan :)
Hey all. Just wondering if there is a part number for the tacho modual in a R33gtst series 1 1995 dash cluster. I want to replace the tacho unit in my cluster. Trying to work out if cheaper to buy new modual part (which i doubt), or just buy a second hand cluster n mix n match parts?
Can you attually just buy the tacho gauge?
part No# 24825 21u01. tacho meter only
hey guys. Need help with part numbers.
I have checked everywhere in nissan fast i can think of and havent had any luck.
Its the metal thing covered in plastic that goes on the doors just below where the window starts (see picture....the thing circled in yellow)
For 1990 r32 gtst
vin HCR32064384
Need the part number for each side.
cheers guys
looks like 80820-04U00(RH) and 80821-04U00 (LH) "moulding assy front door outside"
there is another part 80834-04U00 (RH) and 80835-04U00 (LH) "weatherstrip-front door inside". I think that is between the trim and the window though.
Looks like 80820-04U00(RH) and 80821-04U00 (LH) "moulding assy front door outside"
Thats the one. Awesome work Duncan....cant believe i missed it :(
i know this will be hard to find i would imagine but im after the part no. for a brake master cylinder from a wgnc34 autech 260rs stagea series 1 if possible (i think s1, and s2 is the same)?
i have 34 brembos on the stagea and need a brake booster to suit but i found out 33gtr and 34gtr use different masters i cant see why if they are the same brakes? hopefully the autech one will be the correct one.
thanks
If you have the r34 brembos fitted, wouldnt you be able to use the r34 brake master cylinder? im havin a little difficulty with fast so i cant check right now but im workin on it now. somebody else out there with fast might be able to post up the number before i get around to it.
"it would be easier and cheaper to get after market 1s. google r34 eyelids or use the search button at the top here."
tried the search and majority of em are DIY or from carmate. AFAIK, aftermarket ones are approx 120ish after paiting whereas the nismo ones are around150++. Would rather get nismo in this case
Do you know where can we get nismo eyelids?
thanks mate, i am just wanting to make sure the brake lines all line up with the 34 master thats all, its rather expensive to get it wrong ($300 or so), i cant see why the 34 and 33 would be different?
When i can get fast working ill have a look for a part number. not promising that it will be there though. you could try calling a Nissan dealership and speaking with spare parts. They may be able to help you. If not, try searching yahoo japan auctions. there is several ways to buy from there including Slidewize performance I bought from Zac a few times. always delivered what ive bought. Theres other companies out there that can buy from the auctions on your behalf.
Yea expenses suck. There could be numerous master cylinders that will line up. Maybe best speaking with a mechanic. You might be able to find a cheaper alternative to the R34 1. Ill try to find the number when fast is working.
thanks
Sorry for the inconvenience but its been ages since ive used fast and i have actually never looked for stageas before. can you make it easier and supply me with a vin number? that saves me a lot of stuffing around
ive had a look but i haven't been able to find it. maybe someone else that has fast would be able to track it down.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
