I lost my FAST install in a PC rebuild accident... :)
Can someone tell me if an S13 with a CA18DET(89) and a SR20DET(92) have the same clutch master cylinder?
i would so no, none of the numbers line up
Would you know the part numbers for the door window seals that are connected to the interior door cards on a R32 four door by any chance? mine are more wrinkled than my gran!
RHF 80834-01U00
LHF 80835-01U00
RHR 82834-01U00
LHR 82835-01U00
Hi Neil , is there a part number for the original R34 GTR MFD the whole unit including the housing, thanks
cheers,
David.
sorry bout late reply. There are 4 different part numbers for the MFD less the housing 2 for pre 08/00, and 2 for post 08/00
Pre 24845 AA414
Pre 24845 AA415
Post 24845 AA416
Post 24845 AA417
the housing is seperate Part No. 68411 AA400. hope it all help
Pre 24845 AA414
Pre 24845 AA415
Post 24845 AA416
Post 24845 AA417
Thanks Neil , awsome help, most appreciated.
cheers,
David
Hi,
Im hoping that you can help me find the part number for my brake master cylinder. The details are below:
CAR: 1993 R32 gts-t M-Spec with ABS
CHASSIS #: HCR32-292253
MODEL #: KRCR32RGFS3 FA
It appears to be different from most other R32's because apparently mine is a very late model R32 and it recieved a brake upgrade. I think the master cylinder has a 1 inch bore rather than a 15/16 inch bore like most of the others. The master cylinder has BM-50 on the side of it if that helps.
Thanks for any help,
Shaun.
can i please have part number for r33 gtst 1996
turbo studs (that bolt dump pipe on)
manifold to turbo gasket
thanks in advance
Are u sure they are studs my listing has them as bolts in any case Part No. 14434-V0301
and gasket No. is 14415-4P200
gah i dont have FAST installed on this puter, can someone please confirm which part this is.. is it the door trims that sit between the top of the door and the glass??
R32 Skyline
8083404U00
That number is a good number depending on a few other things with your care
