Sorry Neil I don't understand what you mean.. are you asking what type of r32? R32 GTST rb20det 2 door coupe '92
yeah sorry bout that, it is what i meant. it the inner glass weather strip
, sits at top of the door fab.
Could I just remind people that need numbers that it would advantageous to supply the following: (after all u are getting this for free at the expense of someones time)
FOR REQUESTS: Please specify the following, the more the better and easier for me to get the right number for you.
Model: R32 R33 R34 S15 etc
Year: MOST IMPORTANT!
Colour: Colour if body part.
Model Number: Blue plate - Really handy if you get this
Chassis Number: Blue plate - Really handy if you get this
Edited by arbess
Hey, thanks for doing this guys.
Could you help me out with a part number(s) for the rear quarter window rubber seals for a 1993 R32 gtst? So im after the rubbers that go around the rear quarter windows.
VIN 6U9000HCR32292253
Model KRCR32RGFS3 FA
Chassis HCR32-292253
Thanks,
Shaun.
can you guys help.
Need the part number for the Rear Fog Light for the GTR 34.
Its on the rear bumper, Left side (white) is the reverse light..looking for the right side (Red) fog light.
Thanks heaps
Thanks,
Shaun.
bad news for u the rubbers are apart of the glass, so you can't get them as a seperate part. and in advance the part No. for the qtr glasses are as follows
83306-04U00 RH qtr glass
83307-04U00 LH qtr glass
ahh yes its true. not cheap either....
Dammit!!
Thanks anyway.
Shaun.
not sure if it has been mentioned yet but the part number for a genuine turbo to dump pipe gasket on an r32 gtr (should be same for newer gtr's but unable to confirm atm) is 14445-05U00.
hope that helps somebody out :-)
CONFIRMED!!!!
AND I HAVE FAST AGAIN!
From all the PM recently about me getting numbers, i thought it was a good idea to reinstall after i lost my copy.
and remember!!!!! in big bold fk off letters:
FOR REQUESTS: Please specify the following, the more the better and easier for to get the right number for you.
lawl.
  • 3 weeks later...
I dont think they are the same as RB26. Here is what I have for you,
RB25DET 93- 96
- Belt Fan & Alternator AY140-40850-
- Belt Compressor AY140-40910-
- Belt Power Steering and Oil Pump AY140-30845-
also
- Belt Timing 13028-20P25-
- Filter Oil AY100-NS007-
Good Luck,
Added
HI, just got these belts from Nissan Australia and the part numbers are different to the ones above
Fan & Alternator 11720-42L02AU
Compressor 11720-77A01
Power Steering 11950-58S02
I'm just guessing they are the Australian part numbers but not 100% sure.
Can you confirm if they are still correct for the following car
R33 GTSt 95 model
TYPE CHASSIS NO: ECR33-051545
MODEL NO: GGKBRTFR33VDA--JD-
Also is the Thermostat Assy the correct part number as well 21200-42L06
Thanks
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
