part NO. 80570-91L00 same for both sides. by the way they call it a door stiker
Thanks
VIN:GGKBRTFR33VDAAALCC....I THINK thats my vin :P
Id also like the part number for the ruber seals around the door handles.
And complete rear boot mechanism
Thanks
VIN:GGKBRTFR33VDAAALCC....I THINK thats my vin :(
first of all i did a bit of a typo there It' striker (not stiker)
now for some bad news. thats not your vin it will be on the firewall should go somthing like ECR33-(six numbers)
by the looks of things nissan do not sell the rubber seals around the door handle's seperately. get one with every handle by the looks.
boot latch 84630-15U00
I am chasing a part number for the rubber gasket between the 2 halves of the plenum for an R33 Gtst 1997 series 2, or a suitable substitute.
Many thanks
Peter
Gasket between plenum and intake Part No. 14032-75T05.
please look at this and tell me that these are the parts you need. i will supply you with part numbers if they are.post-14067-1186364698_thumb.jpg
i haven't been able to find the gearbox mounts. i do know that you can get the nismo 1s from justjap. Gearbox mounts
maybe arbess will be able to find the genuine 1s for you.
Part number for that seal on the tappet cover that the hold down bolts go through. Item 12364D
May I ask for the part numbers below ?
1.R32 GTS-T RB20DET hcr32
Headgasket
Full engine gasket kit
2.R33 GTS-T RB25DET ecr33
Headgasket
3.R34 GTT RB25DET NEO er34
Headgasket
4.R32/33 GT-R RB26DETT bnr32/bcnr33
Headgasket
Really appreciate it ! Thanks!
Headgasket
Headgasket
Headgasket
Headgasket
we are gonna have to know a estimated year model for each of these, R32 are fairly staight forward. but R33/R34 change headgaskets and engine gasket kits depending on a few things like year model. e.g R33 from 09/97 use the same headgasket as a R34 in the RB25
at least but are different before that
r32 - 93
r33 - before facelift 93-95 ?
r34 - 99 ?
1990 bnr32 RB26DETT
If someone could help me out with the part number or even just the name of the:
clips/plugs that hold the plastic cover across the lower portion of the front windscreen (just below the wipers)
- I think there is around 6 of the plugs -
Thanks in advance,
Dan
Was wondering, im trying to find out what models use the same coil packs and igniter module as mine, here is the result after loading in my vin for the igniter:
Does it mean that every part number listed there will work on my car?
here is another one which is coils, used the vin method again and the part number came up as 22448-o2u11-
In this pic does everything with that part number mean i can use it?
And also in that pic notice the mention of a RB26DTT, not DETT, which would mean a carbie fed rb26, maybe a typo?
Edited by W0rp3D
Are you sure you entered the VIN correctly, as it's coming up with R32 as the series.
Anyway, when theres multiple parts presented look at the "From" and Up To" columns and they tell which model years the part is for.
yeah, then i went into the r32 section to see if there was any in there with the same part number as it spat out for me, which it seems the same part number was also used for all the rb engines apart from the rb20e.
Well R32's use same coilpacks as your r33 s1.
Sticking my VIN into fast i get:
coilpack assembly - 22448-02U11
id like a part number for the front glass-windshield for a nissan skyline R33 jap vin ECR33-053444..
Also, has anyone ever changed theirs? and how much did u pay?
Cheers.
ecr33 front windshield - 72712-24U00
Just trying to figure out what i can use, limits it a bit if im only looking for something of my car, but if i can cover all off r32's as well then it makes it easier to find parts.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
