Hi guys,
can I please have a list of all the ecu numbers for R32 GTR and R33 GTR???
Why? I want replace my O2 sensors and need to be sure which ecu I'm running, it had the later R33 type crank when the oil pump let go.
The numbers on mine is partially rubbed off, I can see
a Large 30
23710 0??02
MEC R128
0621
Thanks guys, your work is most appreciated.
Thanks Lippo, so theres no chance it could be an R33 ECU?
These are the only part numbers listed for an r33 gtr ecu
Whilst the first numbers are the same the second lot on an r33 start with a 2 and end with a 0 or 1
Edited by W0rp3D
don't worry the 33 and 32 gtr ECUs are interchangeable anyway.
more important is the 02 sensor size, the 32 uses the smaller thread and the 33 the larger thread. You need to check that first, it normally depends on what dump pipes you have on the car (most aftermarket ones use r33 style)
And if you have a look at your part number your ecu is for a carbie fed rb26 lol, im assuming its a typo.
But atleast yours is an rb and not a br :blush:
Edited by W0rp3D
Duncan, whilst they do plug in, I'm fairly certain the R33 & R32 GTR o2 sensors work differently. The power fc needs to know which type you are using.
I stupidly remembered that my ECU must be an R32 as it has a chip in it, so definately a R32.
Thanks guys.
Was wondering, im trying to find out what models use the same coil packs and igniter module as mine, here is the result after loading in my vin for the igniter:
Does it mean that every part number listed there will work on my car?
here
actually I'm not sure if thats the right part no you are after, but just go into parts master and you can see where the same part has been used on other models (as above)
Cheers,
Kaz
lol
you need logic to figure it out, you boys have got no hope haha :D
Please send a cheque for $50 and I'll get back to you..
I found it in the start menu just after i posted it :D
here
Cheers,
Kaz
i was wondering how many pages that would go on for before some one mentioned using the master book method. if u want to get real tricky u can also check it again Australian models if u have the AUS part of Fast loaded as well, all you need to do is open up the AUS version of fast then go into the Master book it will load with AUS info. not saying there will be any matches but it's just a thought
hey buddy after gaskets for a r32 gtst 93
rocket cover
water pump
or even a vrs kit would u know how much they normally cost? know its a low ball but worth the ask
cheers
can't help with price's but Part No. as follows
Rocker cover 13270-58S01 and 13270-58S11 LH and RH
water pump is a liquid gasket (something like ultra grey or a three bond, three bond is genuine Nissan Part No. KP710-00150)
VRS 11042-72L26
any chance of getting part numbers for 1998 R34 GTT (ER34) for the centre console .. namely the double din stereo surround (fascia), the aircon surround (fascia) and the 2 brackets that hold the aircon/stereo in the centre console thanks
also does anyone know how long nissan usually need to get these parts from japan ??
Edited by Delta Force
Facia for CD player 68260-AA005
there are 2 types of brkts but i don't read japanese so cant tell which is which part No. as follows
28039-AA000 LH
28039-AA010 LH
28038-AA000 RH
28038-AA010 RH
two types for ac Fascia aswell ( think it may be a differance in the finish)
AC unit Fascia 27570-AA000
27570-AA010
Lippo is right normaly takes about 2 weeks, just depends the the stock situation in japan
Edited by neofenrir34
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
