hey guys im after the following
R34GTR Vspec front lower lip and diffuser
and also for an R34 GTT im after this part for both drivers and passanger side.
ta
Ash
the part comes in a full piece including the left an right side Part No.68104-AA001
R34 GT-R lower lip Part No. 96015-AA440
hey guys, im after two things for A R34 GTT aswell,
first is the Plastic centre console peice thatt goes around the gear stick ( tiptronic not manul)
and also the piece of platic that is the hinge for the centre console, it the bit that attaches the lid to the console (the bit that the arm rest screws into :down:)
cheers
hey guys
this time im looking for the ash tray
for an R34 GTT in Black please!
Thanks
Part No.s
Ashtray: 68800-AA005
Lighter & socket: 25331-AA001
lighter ring (light) 25339-AA000
all the above parts are for pre 08/00 model, later model have different finish if memory is correct. i don't know what colour the ashtray is.
and also the piece of platic that is the hinge for the centre console, it the bit that attaches the lid to the console (the bit that the arm rest screws into :blush: )
cheers
Part No.s
gear stick surround 96941-AA105
as for the centre console lid hinge, looks like u get one with every lid but not listed as seperate item (unless i am going blind)
Hi neil, can you help me out here, I'm looking for the part number for the R34 GTR petrol cover (the part on the rear guard - not the actual inside petrol cap) in Black paint. im putting GTR rear guards on my car and need the petrol cover , a GTT doesnt match as the R34 GTR has the Ripple in it for the flared guard.
thanks,
David.
thanks,
David.
Two different types depending on year model for the guards
05/98 - 01/99
part No.78830-AA100
01/99 -
part No.78830-AA400
it's not a skyline part but i would like to know this part number. its a nissan anti-theft decal
dont know if it is the exact same label only have very basic illustration
Part No. 990A0-C9915
illustrated a Letter K
Hi Neil, thanks for all the info so far,its been most helpful and appreciated indeed.
Could you please tell me the part number for the Nissan R34 GTR Side skirts factory like the one i have pictured below,colour i'm after is in Black
many thanks,
David.
  • 3 weeks later...
Did anyone know the what is these trim color code?
Sunvisor Sky34:
Driver 96400-AA000 or 96400-AA005
Passenger 96401-AA005
All came in Trim color code G, K, W.
I think it have 2 grey and 1 black, but not sure.
(Light Grey, Charcoal Grey, Black)
What color going with what code?
Thanks
I would like to know if r32 gtr radiator shroud is the same as gtst one?...and the part no please.
My vin is BNR32219410
cheers.
i know it is a bit late, but yeah looks like GTS-T and GT-R one are the same
Part No. 21476-04U00
  • 4 weeks later...
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
