Hi
Can you please find numbers for all breather hoses on/around rocker covers RB20det HCR32.
Cheers
not sure if these are the only ones you need but.
11826-04U10
11826-72L10
11826-73L10
they are onto LH rocker cover, then to from LH to RH rocker cover, then RH rocker cover to inlet plenum
Hey there guys im just chasing order numbers or part codes for:
1995 series 1.5 R33 2 door coupe - Drivers side window surround.
1994 series 1 R33 4 door - Lower sealt belt pillar cover.
  • 4 weeks later...
Hi, just wondering if you know the part numbers for a front bumper support for my 2000 4 door GTT , i think its a series II
im after the middle and 2 side supports , they sit right behind the front bumper
and also if you can tell me how i might get my hands on some ....
i rang nissan ...was no good
thanks
Hi,
Im trying to find the part numbers for the R32 GTR bonnet lip, and N1 vents for the front bar (right and left) in gun metal grey. I appreciate that this info is in this thread somewhere but the search function is non functional at the moment and Ive looked through the thread manully with no sucsess. Any assistance is much appreciated.
Cheers, Sandy.
hey got a R32 Gts-t coupe is there a gasket 4 the fuel pump and if there is i'd like to know the part number please also the number for a rear diff pinion seal?
is there numbers for tie rod ends? R/H/F if that makes any difference?
yeah nice thread keep up the good work Thanks
Hi,
Cheers, Sandy.
N1 bonnet moulding part No. 65820-06U25/ f5820-05U00
may have been replace by latter No.
Rh bar vent 62256-05U08
LH bar vent 62257-05U08
Fuel tank sender unit/pump seal 17342-01A00
pinion seal working on r32 08/91-02/93 with hicas, RB20det. part No. 38189-N3111 (there are also 3 other option so need more info)
RHF tie rod end part No. 48520-71L25. for 2wd
in ending more info is needed for correct info
Edited by neofenrir34
Does anyone have the Part Numbers for the following:
R34 GTR with brushed silver dash -
* Ashtray
* Stereo Fascia surround
These numbers suit 08/00 onwards (get local nissan dealer to send a parts query to find out if they are silver)
Stereo surround 68260-AB100
Ashtray 68800-AB100
* Ashtray
Ashtray 68800-AB100
thanks
not sure if these are wat u are trying to explain but
62216-AA010
62217-AA010
ref picture.
try your local dealer again they where most likely to lazy to look the part up
1993 R32 GTs-T RB20DET with hicas (diff is a LSD)
model number: HCR32-290387
but thanks man :P
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
