could someone find part# for R34 GTT (ER34) ..namely the nissan water temperature sensor that sits under the rocker cover just up on the left from the radiator (near the top left hose)
sensor that fit's more or less directly in to the top hose housing No. 22630-44B20
Looking for the part number for the water pump on a R34 RB25DE Neo
I mainly want to know if its the same pump used in my engine as in a 33 RB25DE(T)
water pump numbers are not the same
R33 RB25DET No. 21010-21U26
R34 RD25DE No. 21010-5L327
hey mate sorry to post again but any luck on the weathershields? I'm trying to find these but for a 32 4dr however Nissan parts haven't been able to help :laugh:
i am sorry man i don't have any info on R32 accessory's. But the part No. for them weather shields is G3610-04U01. but i can't tell u if they would suit a 4DR. sorry
anyone can help me? its an ER34:
- RB25det Nissan OEM Main stud
- RB25det Nissan OEM Head stud
- RB25det Nissan OEM Piston Rings (86mm)
basically all the rebuilding parts except gasket kit.
thanks.
Looking for the rear seat cup holder, goes in the centre console between the drivers and passengers seats, can get vin if they differ due to interior trim colour.cheers
To suit a 5/2000 R34 gtt
Edited by EJD001
two type depending on trim colour.
trim code K and W = No. 96965-AA000
trim code G (BLACK) = No. 96965-AA001
Hey Mate
could you please provide the codes for the following :happy:
i tried contacting nissan and they ask for the codes/ vin number, and i dont have a gtr lol...
Reason why im asking about the HCR32 GTR bar is because my friend had a N1 bumper on his Gtst and it fit up like Factory
with the standard front guards :thumbsup:
So was curious if they made a GTR bar to suit Gtst's width...
COLOUR: Spark silver Metallic- KLOG1
PARTS
1. Nissan HCR32 GTR front bumper code?
2. Nissan BNR32 GTR front bumper code?
3. Nissan BNR32 GTR N1 Version Bumper code?
4. Nissan BNR32 GTR front lower lip code?
Your help is much appreciated if you can :D
thanks! :D
Edited by drftps13=D
2001 R34 GTT RB25DET NEO
After part numbers for
Manual flywheel bolts
fan/drive belts
spigot bush
thermostat
oil filter
Thanks
Flywheel Bolts 12315-42L11
P/S Belt 11720-V7300
A/C Belt 11720-77A01
Fan & Alt Belt 11720-AA001
Spigot Bush 32202-B950A
Thermostat 21200-V7206
Oil Filter 15208-53J0A
Hey Mate
could you please provide the codes for the following :)
with the standard front guards :banana:
PARTS
Your help is much appreciated if you can :)
thanks! :cool:
As far as I'm aware, Nissan never made a GTR bumper to fit a GTST.
Could someone with FAST please lookup the Nissan part code for the Clutch Master Cylinder and Slave Cylinder from a 94 series 1 R33 GTST
I found this one earlier in the thread for the master cylinder but am unsure if there was a change to the clutch when they changed from series 1 to series 2
Right-o! The year and RB25DET made it a lot easier. I hope this is right. Gasket Set: 10101-17U27-
The Clutch Master Cylinder for the same year car is 30610-21U91-
Hope these help. Ron
Edited by TiTAN
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
