can anyone help me?
- RB25det Nissan OEM Main stud
- RB25det Nissan OEM Head stud
- RB25det Nissan OEM Piston Rings (86mm)
basically all the rebuilding parts except gasket kit.
thanks.
I've done a search and a quick poke through this thread, but I can't seem to see my answer.
Can anyone confirm the part # for a genuine Nissan R34 GTT gearknob? It's a 32865-? .. wondering if its the 17U00 same as the R32/33 GTR or different.... Does anyone know? Does Nissan FAST have this level of detail?
Thanks in advance.
Does anyone know the part code for the grommet that holds the one way breather for the intake cam cover as seen in the below picture.
It is from an RB25DET from an R33 series 1 and 2 should be the same
Edited by TiTAN
I search the net for a random BNR34 chassis and found this - BNR34 000103
It says the rear spoiler is - 96030Q Air Spoiler Assy-Rear
But then I input in an ER34 chassis number, the rear spoiler is also - 96030Q Air Spoiler Assy-Rear
Weird.
Vin number of BNR34?
hey guys,
I'm chasing the part number for the power steering hose which runs from the resevoir to the power steering pump.
Does any happen to know this?
cheers,
Frank
it would probably help if i included the model number haha - RB25DET S2 (96')
Thanks in advance.
it could be that one, will need more info on your 34 to tell for sure.
part No. 11812-41B00
Weird.
96030Q is the call out number will be the same for most models to find the rear spoiler fast with out the need to go through all the pictures
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
