looking for the part number / numbers for a R34 RB25DE neo ECU.
We have put a NA RD25DE NEO in a R31 and in moving from shop to shop have lost the computer so i need a ECU. can it going is a manual.
so auto or manual ECU numbers will be fine...
so far i can get a
23710 AA110
MEC 05-030 D2 8608
any help would be great
Edited by sir31
Hey all,
Have searched this thread high and low - couldn't find this part could only find GTR:
RB20DET Power Steering Belt. - Anyone know the number ?
Thanks,
Can anyone please tell me the part number for
oem gtr r34 boot spoiler / wing?
I need the complete part number (wing stay and the wing itself)
cheers!
part No. K6030-AA104 should get u out of trouble
so far i can get a
23710 AA110
MEC 05-030 D2 8608
these should help. all based off a RB25DE 2WD.IRS 5MT
05/98 - 07/98 23710-AA100 / 2371M-AA100
07/98 - 11/98 23710-AA102 / 2371M-AA102
11/98 - 23710-AA103 / 2371M-AA103
original No. / superseded No.
OK THESE ARE FOR A MANUAL..
CAN WE CONFIRM THAT THE
23710 AA110
MEC 05-030 D2 8608
I CAN GET HOLD OF IS A r34 rb35de neo DAM JUST NOTICE CAPS SORRY.......
Hello everyone,
I made a thread in general maintenance but no one replied so far so i thought i'll ask here.
I'm looking for the exhaust valve part number for a RB25DET series 2 r33.
I've looked high and low on the internet and cant find it, hope you guys can help a desperate fellow out.
cheers
can anyone help me?
its for R34 GT-T
- RB25det neo Nissan OEM Main stud
- RB25det neo Nissan OEM Head stud
- RB25det neo Nissan OEM Piston Rings (86mm)
basically all the rebuilding parts except gasket kit.
thanks.
anyone can help mee?
Edited by putraged
23710 AA110
MEC 05-030 D2 8608
that ecu suits 05/98-07/98 2wd IRS RB25DE 4AT
Hello everyone,
cheers
Part No. 13202-08U01 suits all R33 RB25DET engines
i think the reason why u don't have a reply is your request is to broad and poorly worded
for example Main stud an Head stud??
do you need head studs for the manifolds or do u mean the head bolts?
main stud i would be thinking the studs for the main bearing caps
and genuine does not list the size of the rings in "mm" only in Oversize from std e.g. .5, 1.0
if u can explain things a bit better i can help u
Hi guys, just wondering if anyone can get the part number for the R32 GTS25 boot sticker? Dont know if there are different colour stickers depending on the paint colour but Im after the silver sticker..
Cheers
-D
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
