Looking for some trim parts for my S15. Looking for the outer door trim that sits on the top of the metal door and has the end that has a bracket that is screwed to the door itself. I need both Left anf Right.
Next is the metal track that runs perpendicular and sits in front of the quarter glasses and is the housing for the rubber seals. I need both sides in those as well.
Lastly, I need all the rubber sealing that fits around the door on the body of the car, not the door, that seals the door to the body of the car. I already have the door rubbers that attach to the door but not the one that attaches to the body. Can anyone help me please as I need these urgently.
If I can get pictures I can confirm. I also need these small items shipped to me in Trinidad in the Caribbean, postal code is TT. If they can be had used as well I am interested as I need them urgently please.
Jason.
Jason.
for the first ones ( door belt moulds ) part No.
80820-85F10 RH
80821-85F10 LH
for the second request i am not to sure the first to No. are retainers that look to hold the top door weather strip. and the seconed No. look to hold the QTR glass it's self
76872-85F00 RH
76873-85F00 LH
82328-92F00 RH
82329-92F00 LH
and for your final request i would need to know more info on your car. I can't help u with shipping or prices, sorry
80820-85F10 RH
80821-85F10 LH
76872-85F00 RH
76873-85F00 LH
82328-92F00 RH
82329-92F00 LH
Thanks again.
Hi Guys
Forgive the idiotic nubi question, but I'm looking for the part number for a '00 R34 GTT (RB25DET Neo) Engine Loom..
If there are multiple part numbers is it possible to get a listing?
Thanks..
Hi Guys
Thanks..
what parts do u need for tis engine wiring loom because there are about 3 looms that do all of the engine bay. and more info would help like a vin number
hey,
do you guys have the part number for the studs and nuts
R32GTR
1. Turbo to dump pipe
2. Turbo to exhaust manifold
is there a part number for a turbo gasket kit
there is a gasket kit Part No. 14401-05U25
If it helps, from what I have been told I need them all, as the car is a NA+T transplant. VIN number won;t be much use as the car is originally a NA and this is to a stock Turbo ECU that is being attempted to get working right :down:
Hence would need part numbers for the stock turbo gear from any 34 GTT, the more the merrier.
  • 4 weeks later...
Hi there,
Can someone help me out with part numbers for:
R33 GTR bonnet hinges; left and right.
R33 GTR bonnet catch/upright.
R33 GTR guard raiser brackets; left and right.
Having a bit of trouble finding these locally so am looking at sourcing them from Japan.
Thanks,
Rob.
Hi can i get the part numbers for:
r34 xenon drivers side headlight
r34 gtr bonnet, fenders left hand and right handside,
thanks.
does anyone know where i can get these parts other than nissan genuine, they keep bothering me about these part/model numbers
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
