^^^ ok confirmation that's the correct part number ^^^
however the switch from nissan is $345... lol
Part No.s 25160-01U02 and 25160-01U03 come up on my system but they may by old numbers by now, looks like it could just have superseded
Hey mate. Was just wondering if you could find the part numbers for the both front door rubbers and rear tail light assy, on a 1993 R32 4 door at all????
V.I.N HCR32297424
MODEL RCR32GFSLAA
Cheers.
80830-01U10 weatherstrip FRT DR RH
80831-01u10 weatherstrip FRT DR LH
are the weatherstrips that fit to the lower sections of the doors
76860-01U11 weather strip body side RH FRT
76861-01U11 weather strip body side LH FRT
are the weatherstrips that fit to the body and seal the glass to the body
B6550-01U60 RH rear taillight
B6555-01U60 LH rear taillight
Thanks. Much appreciated. :D
yes still in use, appears i am the only one responding.
Thanks for helping us out bud
28174-5P600 RH
28175-5p600 LH
those should be close, however being a trim part i would prefer to have a vin number
My vin number is ER34202802 can you confirm the part numbers?
Thanks heaps
  • 1 month later...
28174-5P600 RH
28175-5p600 LH
Thanks heaps
Sorry for late reply. Yes those numbers are the one the vin selects
Hey all,
I am chasing a part number for a passenger side rear Wheel bearing to suit R34 25gt
My Vin is ER34005218
Cheers
Shane
Part No. 43210-AA100/43210-AA000. part has superseded, it will be one of then number. (which ever one works)
  • 3 weeks later...
  • 4 weeks later...
I need a part number for an R32 Spec RB25DE. Is it 21200-42L06 ? As this seems to be the R33 number.
The engine is not the original one for the car, so not much point giving people the vin number. Any help would be appreciated.
I'm looking for the bushing for the link and arm or whatsoever it is call.
Nissan R33 GTS25T S2.
if someone has the page of it in their service manual, it will help me a lot since nissan dealer told me it was to old...
you can send it to [email protected]
Thanks!
    • Thanks for advice chaps   so you would change idler and tensioner bolt as well ? I guess because you thinking they have stretched once ?   i have done some research and on nissan belt and seem to hold 700hp but thinking HKS to be on safe side   i think I put nissan there last time   also thinking of changing cam cover to glass style:)
    • Nissan/Pitwork is fine stuff. HKS is just marketing wank. I personally wouldn't do the idler if it is already new. If it looks and feels fine, it is fine. But as D says - it's cheap to add it to the job. The water pump ditto. Even more so. If it show no signs of problems, then it is nearly new - leave it.
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
